***SOLD***1978 El Camino SS, $6500***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2006, 03:47 PM   #1
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Default ***SOLD***1978 El Camino SS, $6500***SOLD***
***SOLD***SOLD***SOLD***
Updates added where the bold updates are.
Well, it's hard to believe I'm doing this but... I'm being brainwashed by Yamaha to buy a Warrior 8O (the motorcycle, not the quad).
Soooo, here goes:
Price: $6500. Trades??? only for a Yamaha Warrior motorcycle (not the Warrior quad).
1978 El Camino SS
Engine: 350, comp 268 cam, dyna-gear double chain/gears, Vortec heads with screw in studs and high lift springs, Professional Products alum. intake, Edelbrock 1406 carb, accel coil, new plug wires from Summit, new Bosch Platinum plugs, UPDATE:and a brand new high torque mini starter.
Trans: WC T-5 from a '91 Camaro, new clutch, new light weight flywheel, new slave cyl with the braided stainless hose, F-body clutch and brake pedals mod'ed to the G-body bracket.
Rear end: 3.73 open from an '86 Monte w/ new outer axle bearings and seals. I have a stock posi unit that will go with the sale.
Brakes: SSBC dual piston front calipers with Hawks brake pads, stock rotors, B-body large bore master cyl., Russell braided stainless hoses front and back, all new steel lines, rear drum brakes with new shoes/cyls./hdwr and aluminum F-body drums.
Exhuast: Headman headers, Torque-Tech duals with the Monte SS style tails out the bumper, mufflers are Summit Turbos.
Interior: Out of an 1984 Elky Conquista, grey, power windows/locks/tilt, wood grain style dash pieces, steering column from a floor shift G-body, seats out of a Buick Regal (drivers side power), new headliner, new carpet.
Stereo: JVC CD head unit, Legacy EQ, Pyramid 3.5's in the dash, 300w Audiovox 6x9's in the back.
Body: Indigo Blue metallic and GM corporate silver, roll pan and front spoiler from Honest Charleys, new drivers side 1/4 panel.
Wheels/Tires: 16's off a 2001 S-10 Xtreme with brand new Falcon Zeix 245/50/16's
Suspension: All factory F-41 braces, Monte SS rear sway bar, F-body 36mm front hollow sway bar (the hard to find one), KYB shocks, BMR Fabrication control arms in the rear, poly bushings in every bushing location (no rubber anywhere), F-body quick ratio steering box with cooler. Steering components and springs were all replaced just before I bought the car and have appox. 15,000 miles on them.
Cooling: F-body alum. radiator, F-body elec. fan and upper shroud, new hoses and new water pump.
Here are the pics: http://elcaminocentral.com/gallery-album_albun47.html
There are two things that it will need, a carb calibration kit to better match the cam ($35 kit from Summit), and a pinion bearing (starts to howl at 70mph+) I got a quote from a local off road shop of $150 to do the pinion bearing and have the posi installed.
UPDATE: The carb issue is solved, all it needed was a new accelerator pump. It is now smooth as silk as opposed to the hesitations it had before!!
This Elky corners like it's on rails and sets you back in the seat when rowing the gears. Over all it's a nice car, not trophy winner, just a nice fun to drive cruiser that turns heads! But, I have just as much fun, if not more, riding my old GS750 motorcycle. Thats why I've decided to try and sell my SS and go after a newer bike. I'll probably regret it years down the road though :-(
I'm located in Schoolcraft Mi, half way between Chicago and Detroit.
CHVYPWR is offline
Old July 21st, 2006, 06:17 PM   #2
Sol Goode
Obama Nation!
Sol Goode's Avatar
If I didn't just blow some $$ on something else, I would jump all over this.
#YOLO
#meballsohard
Sol Goode is offline
Old July 24th, 2006, 04:24 PM   #3
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
bump
CHVYPWR is offline
Old July 28th, 2006, 10:27 AM   #4
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
CHVYPWR is offline
Old July 28th, 2006, 04:03 PM   #5
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
if only i had the money! that thing is bad @$$!
trogdor the burninator is offline
Old August 3rd, 2006, 03:02 PM   #6
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Up top.
CHVYPWR is offline
Old August 3rd, 2006, 05:43 PM   #7
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
get an '06 8-ball you will kill the warrior in both speed and quality.
Motor Slut is offline
Old August 9th, 2006, 04:26 PM   #8
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
The performance numbers between the two arn't far enough off to matter much. The Warrior barely has better 1/4 mile times and the 60-80 mph roll up times are only like .20 sec. off from each other.
Anyway, BTT
CHVYPWR is offline
Old August 12th, 2006, 03:30 AM   #9
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
CHVYPWR is offline
Old August 16th, 2006, 08:25 AM   #10
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Test drove a Victory 8-Ball yesterday and I'm pretty much sold. Now I just need the SS sold so I can get the bike!
CHVYPWR is offline
Old August 17th, 2006, 07:10 PM   #11
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Bump for updated info!
CHVYPWR is offline
Old August 23rd, 2006, 08:20 PM   #12
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
CHVYPWR is offline
Old August 25th, 2006, 06:23 PM   #13
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Still available...everybody must be broke
CHVYPWR is offline
Old August 25th, 2006, 11:18 PM   #14
littleblue78cj-5
Send a message via Yahoo to littleblue78cj-5
Default this may help
i dont no if you have or not but you could also try to post it on milan dragway site also lapeer dragway and ubly it might help you sell it a little faster also it sounds and looks like a very nice car and the price is well worth it just thought i could help good luck with the sale
joe
littleblue78cj-5 is offline
Old August 25th, 2006, 11:51 PM   #15
hang in there buddy itll sell
Old September 2nd, 2006, 03:24 PM   #16
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
I hope so. I'd like to get a new bike before the season ends!
CHVYPWR is offline
Page generated in 0.27545 seconds with 71 queries
