302 problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2010, 03:14 PM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default 302 problems
Well to start things off my dad's Bronco II has a fuel injected 302 in it.
Seemed to be burning oil more than gas
So this weekend we pulled the motor and yep I was right it's pretty well wore out.
We really don't have much up here for machine shops the closest thing we have is Napa Auto Parts. They claim for under $300 they will take the bare block, clean it and boar it. Anyone ever use them before?
Seems like a decent deal to me. Just would like some more input from others.
Thanks!
Old February 2nd, 2010, 03:23 PM   #2
Does it need to be bored? If you get it bored, you need to buy new pistons and all related. See if its in good enough shape to get a good hone job and reuse what you have.
Old February 2nd, 2010, 05:38 PM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
It needs to be bored for sure... Thinking 40 over.
Old February 2nd, 2010, 07:15 PM   #4
camccardell
tiger blood
camccardell's Avatar
are there nicks in the cylinder walls?
Old February 2nd, 2010, 07:22 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
I don't know if I'd go that big on a 302. Not worth it for 4 or 5 cubic inches.
Old February 2nd, 2010, 07:27 PM   #6
mprmn08
mprmn08's Avatar
if it needs .04 over then theres no issue with that. the cylinder walls arent that thin on them but if it will clean up with .01 or .02 then i would just do that. minimal as possible incase something else happens down then road and you need it again. i can tell you that my buddy had a napa motor built one time and it wasnt very good. now that wasnt the one up there but still take what you want from it. typically you can get a bore and hone for about 200 and that should include a wash in there. figure on about another 50-100 to r and r cam bearings and oil and freeze plugs. if u were closer to me i would say bring it to my shop. but i would say its worth a hour drive in any direction to find a good machine shop not a parts store that just does machining work. just my 2 cents though
Old February 2nd, 2010, 07:51 PM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
If you put the pistons at the bottom of the cylinder you can move them side to side quite a bit.... It's burning a lot a oil too
Old February 2nd, 2010, 07:59 PM   #8
Shotgun
I only wheel with boats.
Shotgun's Avatar
just add bigger rings or use some of that sweet engine restore stuff.
Shotgun is online now   Reply With Quote
Old February 2nd, 2010, 09:12 PM   #9
Yota Bill
since its such a common engine, and good used replacements can be had pretty cheap, I would first look at the total cost to rebuild what you have, and then compare that to a good used or a reman short block...sometimes rebuilding is cheaper, sometimes its not...with the state of the economy right now, I wouldnt be surprised if you could find a whole vehicle with a good engine that you can drive before buying for less then the total cost of rebuild, and then get some back when you scrap the car
Old February 3rd, 2010, 06:51 AM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
x2 on finding a good used engine, or reman shortblock
Old February 3rd, 2010, 07:16 AM   #11
camccardell
tiger blood
I was working at a dealership and someone had installed a new motor from napa, and it was burning a lot of oil. We pulled it apart and some dumass had put the wrong size pistons in the engine. it was off by at lease .010
Since it is obviously not a stock motor, put a mic in those cylinders and check for size / out of round, and then check the pistions. Hell the block might already be bored .030 over and not even worth the money to fix up.
just something to think about
Old February 3rd, 2010, 05:29 PM   #12
mprmn08
mprmn08's Avatar
Define "alot" of side to side. different pistons have different clearances depending on manufacturor and application. we've built motors that .002 clearance and some that have .008 clearance. i would have a shop or u if you have a bore mic check the bores first before you assume. you could just crosshatch the block and put new rings in and be good. also burning oil isnt neccesarily a bottom end issue. you could just new valve seals or intake gaskets. dont just assume the bottom end needs rebuilt though.
Old February 3rd, 2010, 06:45 PM   #13
bigarsetrucks
Barkeep I need a DRINK
bigarsetrucks's Avatar
I wouldn't let a napa machine shop hone a briggs and stratton. The last engine I tore down that they "rebuilt" had 3 different sized rod bearings and 2 different sized main bearings in it. Poor quality work from them, at least in my experience with them.
bigarsetrucks is offline   Reply With Quote
Old February 4th, 2010, 09:42 AM   #14
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I don't have a bore mic. But my roommate (mechanic) also agrees it's WAY to much slop the timing chain is also about ready to snap I'll make a call across the river ( canada ) I heard there is a good machine shop over there.
Thanks guys
Old February 4th, 2010, 01:54 PM   #15
Fraser
Fraser's Avatar
sounds like your crank wore funny. prob could have line honed the block and turned the crank down to run the same stuff tho
Page generated in 0.37439 seconds with 68 queries
