bronco - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 1st, 2010, 11:27 PM   #1
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Default bronco
ok so im new to Ford.. Just traded my Tahoe for a 1985 bronco.. mint body 351 blah blah... It has that funky front indepent axle in it.. I was wondering whats better that or a solid ford 44 or 60? and would that axle just drop in or do I have to make shackes and stuff for leaf springs? right now I have coils and I think a four inch lift?
AJ Hall is online now   Reply With Quote
Old February 2nd, 2010, 12:04 AM   #2
Yota Bill
obviously the D60 is better, and the 44 could be a better option then the TTB, depending on what you are doing with the truck
to do the SAS, yes, you will need to do some fabricating, its not a bolt in and go sort of thing
to decide if its worth it, you first need to decide what your plans for the truck are
Old February 2nd, 2010, 01:21 AM   #3
masterbeatty
masterbeatty's Avatar
ive solid axled both my broncos and its definetly worth it. they ride better and wheel so much better.
Old February 2nd, 2010, 08:42 PM   #4
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
thanks guys... really because I figured the ttb would ride better.. hmm... Im only going to run like 35s or 37s.. its already lifted a little with 33s.
Old February 3rd, 2010, 07:48 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
a sas with a dana 44 is a waste of time, unless you have nothing better to do or your front is trashed, there is no reason to swap out a ttb 44 for a solid 44 if it is in working order
Old February 3rd, 2010, 03:03 PM   #6
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
go on fullsize bronco .com, it has all the answers to your questions. I was toying with the idea myself. it covers both leaf spring and coil spring swaps. if it were me coils would be easyer.
ATOMIC_BADBOY is offline   Reply With Quote
Old February 3rd, 2010, 11:55 PM   #7
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
haah I JUST made a account there and was looking around. Thanks.
Old February 6th, 2010, 08:48 AM   #8
El Jefe
El Jefe's Avatar
TTBs DO ride better than solid axles- regardless of what anyone says. they have less of an unpsrung mass input into the suspension and are a compromise similar to a IFS , so a softer ride is accomplished with TTBs.
the downsides are: more difficult to align, much less lift friendly (gotta mess with the knuckles and shim them) and tire wear is more prevalent on a TTB than on a solid live axle.
I agree with the stated post that there isn't much gained in swapping the D44 TTB to a SLA D44 if the TTB is in working order. leaf springs are NOT a better option for a front suspension than coils (for ride characteristics).
If you're swapping to a D60 then that would be a different story....
El Jefe is offline   Reply With Quote
Page generated in 0.36693 seconds with 47 queries
