*SOLD*remote trans cooler from '92 Ram 250 w/ Cummins - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2010, 05:10 PM   #1
addicted
addicted's Avatar
Default *SOLD*remote trans cooler from '92 Ram 250 w/ Cummins
This came off of the '92 Ram I used to own. It is the dealer installed under bed auxillary cooler. It doesn't leak the wetness is from the hoses that were leaking and comes with a cooling fan and temp sensor.
$75 OBO
addicted is offline
Old January 30th, 2010, 05:16 PM   #2
mudbillyredneck
mudbillyredneck's Avatar
does it have the t-stat included (built in ) or is it just wired for direct on & off ?
mudbillyredneck is offline
Old January 30th, 2010, 06:02 PM   #3
addicted
addicted's Avatar
I'm fairly certain that it is a thermostatic switch since there weren't any switches in the cab to run it.
addicted is offline
Old January 30th, 2010, 06:23 PM   #4
mudbillyredneck
so , if you run jumper wires to it..it will not run untill it see's operating temp ?
Could you check ?
I'm kind of in the market for one of those ( would you consider shipping ? )
Old January 30th, 2010, 06:46 PM   #5
addicted
addicted's Avatar
It has seperate plugs for the fan and temp sensor. The fan is a factory XJ a/c auxillary fan and it does work when jumped. After thinking about it more and remembering how it was set up under the bed when I removed it, the wires weren't hooked up to anything and were wrapped around the harness that ran along the frame. So the temp switch may or may not be good.
I will ship, on your dime of course.
addicted is offline
Old February 4th, 2010, 03:40 PM   #6
addicted
addicted's Avatar
ttt
addicted is offline
Old February 18th, 2010, 10:32 AM   #7
addicted
addicted's Avatar
ttt
addicted is offline
Old February 25th, 2010, 01:42 PM   #8
MiNi Beast
MiNi Beast's Avatar
pm sent thanks
MiNi Beast is offline
Old February 25th, 2010, 02:51 PM   #9
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
shipping????? or where exactly are you located
hosejockey4506 is offline
Old February 25th, 2010, 03:02 PM   #10
MiNi Beast
MiNi Beast's Avatar
Already mine fool.
Old February 25th, 2010, 03:30 PM   #11
addicted
addicted's Avatar
I'm about a half hour west of Fenton. If you'd only have found this thread 3 hours sooner.
Originally Posted by MiNi Beast View Post
Already mine fool.
I'll give you a call later Roger.
addicted is offline
Old February 26th, 2010, 08:26 PM   #12
addicted
addicted's Avatar
sold
addicted is offline
Page generated in 0.28777 seconds with 59 queries
