dodge trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2010, 04:04 PM   #1
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
Default dodge trans
are the automatics better then they use to be? lookin at a 2500 hemi or cummins 03 to 06
bigjay is offline   Reply With Quote
Old January 29th, 2010, 08:27 PM   #2
mprmn08
mprmn08's Avatar
the gasser trans are and the cummins ones get better after after 04.5 and the 08's and newer are awesome.
Old January 29th, 2010, 09:37 PM   #3
84Scrambler
My 2004.5 is up to 143,000 miles with no issues so far. I've pulled heavy a lot with it and haven't been kind to it.
Old January 29th, 2010, 09:40 PM   #4
bigjay
bigjay's Avatar
what changed from 04 to 04 1/2..?
Old January 30th, 2010, 01:48 PM   #5
bigjay
bigjay's Avatar
the 6 speeds of the same yr anygood also?
Old February 3rd, 2010, 08:43 PM   #6
dline
dline's Avatar
6 speed auto?
dline is online now   Reply With Quote
Old February 11th, 2010, 11:12 PM   #7
Coal Burner
MAKE IT OR BREAK IT
Coal Burner's Avatar
If your talking Cummins w/ a standard trans.
For an everyday driver the tranny is fine w/ no mods, if you want to get some fuel/air and make some power you would want to get one w/ a NV5600
(00-04) rather than a G56 (04.5-current). now you can do a nv5600, G56 swap takes a little bit but can be done.
Coal Burner is offline   Reply With Quote
Old February 15th, 2010, 01:42 PM   #8
nickb304
nickb304's Avatar
i would go 06+ on a 2500 hemi. 03-05 have tow haul mode but no way to keep it from shifting into overdrive. 06+ you hit the button once to put it into tow haul mode where it locks out your 5th gear overdrive but still uses 4th gear overdrive. hit the button again to put it in third (direct drive) and lock out both overdrive ratios (4th and 5th). lots of 03-05 drivers complained about the gear hunting between 3rd and 4th with a heavy load and it caused more wear on the trans. the ctd seem to be fine when left stock.
nickb304 is offline   Reply With Quote
Page generated in 0.17683 seconds with 47 queries
