Where is the cummins rpm sweet spot? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2010, 08:40 PM   #1
kkodet
kkodet's Avatar
Default Where is the cummins rpm sweet spot?
For those of you who run cummins motors, maybe you can help.
I've got a 12 valve 1990 non-p pump cummins I'll be swapping in my suburban with an NV4500 and solid axles.
My plan for this rig is to be mainly my tow rig, but also be a mild family wheeler.
Where do you like to see your cummins running for RPMs:
For towing?
For driving daily?
For the best fuel mileage?
Old January 26th, 2010, 09:42 PM   #2
trooper
trooper's Avatar
trooper is offline   Reply With Quote
Old January 26th, 2010, 09:48 PM   #3
kkodet
kkodet's Avatar
Originally Posted by trooper View Post
2250
For what? Towing, DD, wheeling?
Old January 26th, 2010, 11:33 PM   #4
boggin-machine
boggin-machine's Avatar
i run damn near 2k which puts me at 70 72 with 285x75 bfg at with a ats 47re tranny
Old January 26th, 2010, 11:53 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I set the cruise on 80 and relax. *lol*
JcrOffroad
Zoom Zoom!
Old January 27th, 2010, 12:11 AM   #6
mudbillyredneck
mudbillyredneck's Avatar
1,800 is what I thought for MPG's
But what do I know...I'm running a 12V Crewcab on 40's with 4.10's and a 47RH auto
mudbillyredneck is offline   Reply With Quote
Old January 27th, 2010, 06:08 AM   #7
Yota Bill
same engine, completey different machine, but most of the heavy equipment I work on with the Cummins has the high idle set at about 2200-2250...this is the point (in these applications anyway) where the high points of the torque curve and fuel efficiency meet..granted, there are other factors (hydraulic p/q curve, engine pull down, exhaust noise level, etc) but every engine will vary slightly anyway, so this should be a good starting point for you
for times of less load (daily driving, etc) and MPG is the biggest concern, I would think somewhere around 1800-1900 RPM would be a good place to be
Old January 27th, 2010, 06:50 AM   #8
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
About 1900 is the sweet spot on a 12v. That is where it makes most of its torque and runs efficiantly (sp?).
RIP FULLSIZE4LIFE
Old January 27th, 2010, 07:22 AM   #9
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
Look at what most dodges with a cummins had for gears, 3.55.
Shoot for something around that and the rpms will be fine.
One other tip, get a 3k governer spring for that VE pump, the extra rpms will be helpfull especially if you go with lower gears.
Old January 27th, 2010, 07:26 AM   #10
butters
It curves to the left...
butters's Avatar
My 95 with 3.55 gears gets around 17 mpg if i can keep it around 1800-1900 rpms
thats doing 70-75 mph. pulling at the same rpms i have seen 13-14 mpg
butters is offline   Reply With Quote
Old January 27th, 2010, 07:36 AM   #11
mudmafia
Dr. X equals winnar
mudmafia's Avatar
2000 for MPG, and its a 6 speed so i call the shots lol.
mudmafia is offline   Reply With Quote
Old January 29th, 2010, 07:33 PM   #12
mprmn08
mprmn08's Avatar
17-1900 for best mpgs/dd and about 2000-2200 for towing. i dont care what anyone says over 2000 will not get you best mpgs in a cummins
Old January 31st, 2010, 11:12 PM   #13
noodles
give 'er sh*t ay?
noodles's Avatar
the engines are designed to run between 1200 and 1800. thats where the most power and torque come out of the cummins. when i was at the dealership thats what they recommended. dont lug the motor though, on the big motors it causes fretting of the block. never seen it on a "B" but it could happen
Page generated in 0.28704 seconds with 62 queries
