1979 Jeep J10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old January 26th, 2010, 02:28 PM   #1
manicjester3
manicjester3's Avatar
Send a message via Skype™ to manicjester3
Default 1979 Jeep J10
parts:
-engine - amc 258 inline 6 runs with flywheel and clutch - $150 WITH MC2100MC2100 SOLD
-trans - (2) t-176 one has bad synchros only one bellhousing - $200 for the good one and bellhousing, $50 for the bad one - SOLD
-transfer case - dana 300, makes noise when coasting - $150
-axles (4) - dana 44 front, passenger side drop, 3.54 gears (I think), lockright locker, new warn premium locking hubs, 6 lug - $250 - SOLD
-dana 44 hd front, passenger side drop, soa perches, 5.13 gears, lockright locker, 8 lug - $300
-dana 60 rear, full float, centered pumpkin, unknown gears - $100
-dana 60 rear, full float, offset pumpkin (quadra track), 5.13 gears, full spool - $300
-suspension - 3 inch leaf spring lift all around - $200
-frame - pretty rough on the drivers side from cab back, welded in some spots - $Make offer
-body - front fenders - good shape - $100 each
-core support - some rust holes and pitting from sand blasting - $100
-hood - good shape - $50
-drivers door - bad shape, mirror ripped off on tree and dented door a lot window and latch work well - $Make offer
-passenger door - good shape - $50
-bed - fair shape, some dents along passenger side, tailgate has some dents but mostly good shape - $300
-cab - good shape, seats from 2009 dodge challenger, also have factory bucketts, floor is solid, patch panel in drivers side floor, sliding rear window, spare solid rear window - $300
-all body parts have been sanded, epoxy primered, and painted with single stage factory match acrylic enamel, and has herculiner coating on rockers, fender flares and up to first body line
-custom front bumper made from 2.5 inch od 1/4 inch wall tube with stinger - $make offer
-also have an ax15 trans with Novak adapter for dana 300 - $150 for trans, $75 for Novak adapter, adapter fits AX15, AX5, AW4, 904/909, NV3550 and NSG370.
manicjester3 is offline   Reply With Quote
Old January 26th, 2010, 03:02 PM   #2
dadof3byz07
Just laid back
dadof3byz07's Avatar
How much for the springs?Do you have a good gas tank,and rear bumper?Thanks!
dadof3byz07 is offline   Reply With Quote
Old January 26th, 2010, 03:20 PM   #3
addicted
addicted's Avatar
Got pics of the front bumper and how much?
addicted is offline   Reply With Quote
Old January 26th, 2010, 03:28 PM   #4
manicjester3
prices added
I'm looking for about $200 for the springs. I have a gas tank for a 79 and one for an 80. They are different, one has the fill/vent hoses on the side, one has them on the front. Let me know which one you have. I have a rear step bumper from an older Chevy van on it. It's about 2 inches wide on either side, but the frame mounts are the same width apart.
Old January 26th, 2010, 03:36 PM   #5
manicjester3
I don't know what to ask for it, I spent about 18 hours fabricating it and I ended up welding it on, so I had to cut off the mounting tabs to get it off.
ID:	56524   Click image for larger version
Old January 26th, 2010, 03:42 PM   #6
addicted
addicted's Avatar
Not really what i'm looking for but thanks for getting the pics up.
Old January 26th, 2010, 05:53 PM   #7
J Truck Rick
J Truck Rick's Avatar
I'm interested in the cab&bed(but you knew that)......
J Truck Rick is offline   Reply With Quote
Old January 27th, 2010, 08:02 AM   #8
bigjeep65
Lurker
bigjeep65's Avatar
What width(s) are the 44 fronts? Both from trucks?
Thanks
bigjeep65 is offline   Reply With Quote
Old January 27th, 2010, 04:19 PM   #9
orionn
orionn's Avatar
PM'd you
orionn is offline   Reply With Quote
Old January 27th, 2010, 10:50 PM   #10
manicjester3
Both axles are from a truck. Not positive on the width. I can check this weekend.
Old January 28th, 2010, 09:25 AM   #11
ronprice
ronprice's Avatar
44 and 60 with 513'sredy to install or need rebuild.
ronprice is offline   Reply With Quote
Old January 28th, 2010, 09:41 AM   #12
manicjester3
They're ready for install. They're still on the truck actually.
Old January 28th, 2010, 02:08 PM   #13
cannaert
No more Jeep
cannaert's Avatar
Grill How much. I want that one over the Final addition grille
Old January 28th, 2010, 02:43 PM   #14
rockrat
rockrat's Avatar
trade for a 5 ton rear
rockrat is offline   Reply With Quote
Old January 28th, 2010, 02:54 PM   #15
manicjester3
PM sent
Old January 28th, 2010, 03:05 PM   #16
manicjester3
Don't have any need for a 5 ton rear, sorry.
Old February 1st, 2010, 01:26 PM   #17
manicjester3
Here is a link to all the pictures of parts I took this weekend. If I missed anything, let me know, I can take more Wednesday.
http://s130.photobucket.com/albums/p255/manicjester3/
Old February 2nd, 2010, 11:18 AM   #18
manicjester3
Updated. 258 has MC2100 on it already. Also have factory intake and exhaust with factory carter BBD carb.
Old February 4th, 2010, 01:30 PM   #19
manicjester3
MC2100 Sold
Old March 4th, 2010, 01:18 PM   #20
manicjester3
Bump
Page generated in 0.42899 seconds with 84 queries
