need info on my ram charger - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2010, 03:12 AM   #1
nick!
Default need info on my ram charger
did a body lift on my truck 3inch,the clutch asembily for the clutch pedal is all twisted and now i have barlley and clutch pedal its not hydrolic just manual does anyone know how to fix this thanks
nick! is offline   Reply With Quote
Old January 26th, 2010, 05:01 AM   #2
Blazin_wheeler
turtles like me
Blazin_wheeler's Avatar
you should post this question in "General Tech"
Blazin_wheeler is offline   Reply With Quote
Old January 26th, 2010, 10:06 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
5. Manual transmission.
a. If the vehicle is equipped with a hydraulic clutch it requires no modification.
b. If the vehicle is equipped with a manual clutch linkage, remove two spring clips from clutch linkage and clutch mechanisms. Remove clutch linkage from vehicle.
c. Scribe a line along clutch linkage at the bottom (toward the ground) of the clutch linkage rod.
d. Cut the clutch linkage through the scribed line.
e. Position shift extension pin between the two pieces of the clutch linkage. Align the scribed line and weld the extension in place.
Page generated in 0.24344 seconds with 32 queries
