The Houdini 318 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2010, 02:14 AM   #1
RANGER_DANGER
Now I Got a V8!
RANGER_DANGER's Avatar
Send a message via AIM to RANGER_DANGER
Default The Houdini 318
My 1994 2wd 1500 with a 318 is mysteriously getting rid of its oil. It only leaks around the valve covers and it doesn't burn it. I am seriously about a quart and a half low when I change the oil sometimes more. I only use synthetic in it and I am the second owner of the truck. My grandpa was the first owner and I KNOW he kept up on it.
Any ideas about where this oil is going?
RANGER_DANGER is offline   Reply With Quote
Old January 26th, 2010, 05:16 AM   #2
JeepInABox
In too deep
JeepInABox's Avatar
The 318's are known to have a intake manifold lower pan leak that can burn up to a quart evert 1000 miles and not smoke.
1.5 quart per oil change is not really worth fixing, just check your oil once a month.
Old January 26th, 2010, 11:55 AM   #3
RANGER_DANGER
Now I Got a V8!
Okay, it isn't getting any worse but i really wanted to know where the hell it was going. Thanks a lot!
Old January 26th, 2010, 01:00 PM   #4
84Scrambler
Pull the air intake off the throttle body. Look down through the air intake. If it is wet/oily, you have a leak. There is a seriously thin metal plenum with a gasket on the bottom of the intake manifold that is notorius for failing. There are several aftermarket replacement plenums made from slightly thicker metal that won't warp and allow that gasket to blow out.
Page generated in 0.20497 seconds with 35 queries
