ford explorer needing new oil pump? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2010, 10:13 PM   #1
zachattack2795
Default ford explorer needing new oil pump?
my jeep blew a head gasket and i was offered to trade a 1998 ford explorer for my snowmobile so i can still have a vehicle to get around in while the jeeps getting fixed . the explorer has low oil pressure so it needs an oil pump. im going to limp it back home. I was told by the owner that there is some vibration from the rod bearings going due to the low oil pressure. can i expect more problems from this? can i do the rod bearing with the engine in the explorer? I know its not a jeep but it'll have to do until mine is fixed.
zachattack2795 is offline   Reply With Quote
Old January 25th, 2010, 10:16 PM   #2
Yuo have to really lift the motor high to clear the crossmember..........changin a pump on an explorer is more work by quite a bit then changing a head gasket on a jeep
Old January 25th, 2010, 10:19 PM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
i would keep my sled and figure something else out. it makes no sense to have 2 broke down rides.
Old January 25th, 2010, 11:39 PM   #4
Yota Bill
X2
sounds like the expolorere is due for an engine rebuild or replacement
Old January 26th, 2010, 07:05 AM   #5
zachattack2795
its got a new top end on it but if I gotta lift the engine might as well get something ele.
Old January 26th, 2010, 07:08 AM   #6
Bones
Bones's Avatar
a simple 10 second look under the engine would have told you that you have to pull the engine to remove the pan and work on the crank.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 26th, 2010, 09:41 AM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Low oil pressure usually means there is too much clearance in your engine - specifically the bearings. The engine in the Explorer is not long for this world, steer clear of it.
You do this trade and you will hate yourself for it. We will also remind you that we told you to stay away from it any time you ask for help on it.
@clarkstoncracker
Old January 26th, 2010, 10:33 AM   #8
zachattack2795
its the explorer, a rusty toyota on 33's or an escort wagon and im not a station wagon kinda guy.
Old January 26th, 2010, 01:07 PM   #9
kkodet
kkodet's Avatar
Go for the rusty toyota. Those things seem to run forever.
As the other guys said, the explorer will need much more than just an oil pump. Low pressure is probably not the pump, but all the internal bearing surfaces being over spec and worn out.
Old January 27th, 2010, 09:35 AM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
i have been driving my 4L explorer with near zero oil pressure for over a year
i replaced the pump, but the cam bearings were to shot for the new pump to make a difference
If it has a 4L it can be done without removing the engine V8s have to come out though
Old January 27th, 2010, 10:25 AM   #11
zachattack2795
yours looks lifted in your picture, d that make a difference? can I still drop the pan on the stock one? I might do the rod bearing at the same time, is that doable with the engine still in?
Old January 27th, 2010, 02:08 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
If you're having your jeep fixed, you aren't ready to tackle this project.`
@clarkstoncracker
Old January 27th, 2010, 02:35 PM   #13
zachattack2795
I can do most mechanical sutff, the only thing that scares me about the head gasket is the timing. im sure I can do the oil pump but im not sure I can remove the engine to do it
Old January 27th, 2010, 04:03 PM   #14
fsumotorhead
N8KVB
mine isn't really lifted
yeah it's probably doable, keep in mind you have to pull the CVs, pull driveshaft, drop out the axle (3 bolts), i didn't even have to lift the engine off the motor mounts.
The one thing i had to go out and buy was a torx bit that was +6" long
Old January 31st, 2010, 03:38 AM   #15
Fraser
Fraser's Avatar
wat? changing a head gasket on a jeep 4L doesnt affect anything timing related. you just have to keep all your parts organized.
Page generated in 0.25341 seconds with 68 queries
