Trailer lights not working right. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2010, 10:26 AM   #1
xNewhaven11
Four Wheel Drive
xNewhaven11's Avatar
Send a message via AIM to xNewhaven11 Send a message via MSN to xNewhaven11
Default Trailer lights not working right.
I recently ran new wires on my trailer because the old ones only worked sometimes since they were getting old. After hooking the new wires up the lights stay on solid and only flash very dimly, you wouldn't be able to even tell unless you really looked.
I ran a ground wire from each light going to the frame, its not bare metal but there is no rust or anything.
If i cant figure it out i will grind it down and try to touch it to the bare metal.
When i turn my headlights on, they are solid.
When i brake, nothing happens,
When i use a turn signal, they barely work,
When the lights are off on the truck, they don't work at all.
Any other ideas of why its doing this?
xNewhaven11 is offline   Reply With Quote
Old January 24th, 2010, 10:37 AM   #2
rider50
rider50's Avatar
bad ground between the vehicle and the trailer !!!!!!
rider50 is offline   Reply With Quote
Old January 24th, 2010, 11:20 AM   #3
xNewhaven11
Four Wheel Drive
Wired a new 7-pin connector to try that, still having the same problem.
What else can i do to mess with the ground?
Old January 24th, 2010, 11:35 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
clean the frame for the grounds
H.o.r.e
Old January 24th, 2010, 12:13 PM   #5
stuckinthemud
stuckinthemud's Avatar
alotta trailers ground through the hitch make sure its clean inside where the ball goes in an make sure ball is clean
stuckinthemud is offline   Reply With Quote
Old January 24th, 2010, 10:30 PM   #6
Yota Bill
sounds to me like your lights are hooked up backwards...you have the brake/turn lights wired as the running lights, and the running lights (which are much dimmer) wired as the brake/turn lights
what does it do when you turn on the 4 ways, turn signals, or brake lights when the running/headlights are turned off?
Old January 25th, 2010, 02:01 AM   #7
crazygrady127
crazygrady127's Avatar
Yeah sounds like a bad ground !!! A bad ground wire will make your lights do all sorts of crazy things !! Or it could be in the pig tail coming from your truck to trailer ? Those go bad all the time !!
crazygrady127 is offline   Reply With Quote
Old January 27th, 2010, 01:21 AM   #8
crazygrady127
Well, Any luck yet ??
Old January 27th, 2010, 05:17 PM   #9
xNewhaven11
Four Wheel Drive
Still working on it sadly, havent had much time but i am pretty close.
The connection on the truck was a little dirty and had some corrosion so i cleaned that off, Checked the 7 pin and re-wired that to match the truck again to make sure and cleaned the frame for the grounds perfect.
Still having the problems but i then narrowed it down to the harness between the lights.
Touched the wires around and i am pretty sure one wire was loose.
Tomrrow i am going to sotter and shrink tube it so i should be all set.
Will post results.
Old February 21st, 2010, 11:39 PM   #10
crazygrady127
So, what was it ??
Old February 21st, 2010, 11:46 PM   #11
special k
special k's Avatar
sounds like to me either the wires are hooked up backwards or the bulbs are in the sockets backwards, i know I've done them both with same result. if you have a bad ground if all else fails you could run your trailer ground wires right to the ground wire on your flat 4 connector or seven pin, which ever you end up using. that way as long as your trailer wiring on the car end is good, you'll have a good ground connection.
Old March 2nd, 2010, 04:25 AM   #12
crazygrady127
Good call , never thought of doing it that way !! it would have to be a quick fix of coarse but it would work !!
Old March 2nd, 2010, 06:38 AM   #13
j_little3
Boris
j_little3's Avatar
you dont need to be grounded between the trailer and vehicle
j_little3 is offline   Reply With Quote
Old March 2nd, 2010, 07:19 AM   #14
Nuggets
I fix stuff!
Nuggets's Avatar
You sir don't know jack shit about trailer wiring.
Old March 2nd, 2010, 07:36 AM   #15
j_little3
Boris
j_little3's Avatar
I work at a trailer place... You need a ground on the vehicle and the trailer connected through the plug.
I was thinking he was saying grounded together through the ball. Thats what you dont need.
Old March 3rd, 2010, 07:25 AM   #16
L4CX
Out for the Summer!
L4CX's Avatar
X2. The Terminal is what the trailer is supposed to be grounded through, not the ball. If the ball would need to be a good conductor it would need to be clean. If it was clean, it would squeak and wear down the ball. Not only that but then when ever you hit a Bump the lights flicker. The Ball (or part that goes on top of it) should be Lubricated lightly.
If it's a Ground issue then usually the Trailer lights will blink oppisite of the Tow Vehicle. This indicates the Electricity trying to get back to the Battery through the (+) side of the wiring. They should blink together. My dad had this old trailer that the wiring was a mess. I refurbished it a couple years ago. It's been great since.
L4CX is offline   Reply With Quote
Old April 13th, 2010, 10:13 PM   #17
yammie125
^^^ of course you need to be grounded between trailer and vehicle.
yammie125 is offline   Reply With Quote
Page generated in 0.58250 seconds with 74 queries
