~mpg~ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 24th, 2010, 08:01 AM   #1
chevybtk
~~1995 chevy k2500~~
chevybtk's Avatar
Talking ~mpg~
My 1992 k 1500 5.7 liter gets 10mpg highway and about 6 city..... is there anyway i can increase that or what kinda of pluga and stuff to run in it, or set up to increase that i have a cherrybomb w/no cat on there now w/duel 2-1/2 after muffler and dumps and rear axle, should i take that off and put a regular muffler on?..... I have standard AC wires, autolite copper plugs, 285-75-16 tires (but look goofy with smaller tires because i have a 3 inch body lift)....and also truck has very little power.......Could trans need replacing it has a bout 250K on it that dosent like OD on e-way but will stay in if i dont use cruise.........just need some advice guys......what should i run...
chevybtk is offline   Reply With Quote
Old January 24th, 2010, 08:16 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Hard to say whay you have so bad of mpg and week power, but I would be looking at doing some basic engine checks. Compression test the engine to see how worn your valves and rings are. also check your TBI. if you open the butter fly are the bottoms of the plates black and dirty looking? if so then you need to clean that crap. some times the ports in the TBi become very coked up and then it restricts the function. also the injector pod. I have seen old ones worn to where they drip badly while running. if you shoot a timing light at the fuel spray youll see the pattern. if you see alot of drips then you most likely have a worn out injector. replace as you see fit. just remember that gas as a liquid doesn't burn, it goes right out the pipe. the drips don't burn.
Yetti
Old January 24th, 2010, 08:27 AM   #3
chevybtk
chevybtk's Avatar
Yeah thanks injectors are new BTW...just did them about 5k ago......no drips and have a nice fan pattern...
Old January 26th, 2010, 02:09 AM   #4
chevybtk
chevybtk's Avatar
Any other opinions???
Old January 26th, 2010, 02:37 AM   #5
MilwaukeeF350
Dan
Ok can you add vacuum gauge? Then drive around city or highway what psi it at while drive.
Below 12 psi = terrible mpg. 13 or up= good mpg. 20 psi= BEST MPG.
It impossible to keep 20 psi myself.
Is brake drag? Isn't it in 4x4 mode ?
If that mpg was in winter that kind normal but little low.
Old January 26th, 2010, 02:47 AM   #6
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
You're 3" body lift and larger than stock tires are going to kill your mileage all by themselves! I had a '98 ext cab Z71 that got 12.5 mpg no matter what!
I also had 285-75-16 tires and 2" lift. Installed new heads, complete everything tune-up, new O2 sensors, new cat converters, new cat back aftermartket exhaust and still was 12.5 mpg. Those big trucks are thirsty, you'll never have "good" MPG out of them.
You're biggest mileage improvement will come from driving habits. I changed my driving habits with my Blazer and went from a 15mpg average to a 17mpg average. My highest was damn near 20mpg city. Not bad for a brick!
Look here for some tips: http://www.gassavers.org/index.php
Old January 26th, 2010, 06:50 AM   #7
Disturban
Disturban's Avatar
My 88 suburban 5.7 liter with slight mods gets 10cty and 10hyw all the time. Not much you can do with these big old chevy's.
Old January 26th, 2010, 10:10 AM   #8
chevybtk
chevybtk's Avatar
thanks guys.....
Old January 26th, 2010, 10:34 AM   #9
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Only the lift will make a difference, your pushing more air with a body lift, but the 285s aren't going to make much of a difference if any at all, I have 285s on my 96 and still get 15-16 city
Your best option is to consider rebuilding/replacing the motor and transmission, but transmission definitally if it's has 250k, then i'd consider upgrading your ignition system and air intake, you can pick up a set of headers to replace the stock manifolds, all that should increase your mpgs but at least 2 or 3, maybe more. Depending on what you use your truck for you could swap in a 4.3L v-6 or a 5.0L v-8. Couple that with the other mods and you could be looking at an mpg increase of at least 4 maybe 5 or 6 miles per gallon.
But like I said, rebuild/replace the motor and definitally do the transmission, if you do anything to the motor throw a set of vortec heads on
Old January 26th, 2010, 10:46 AM   #10
greygoose
I'm the dude
greygoose's Avatar
383 TBI. Nice upgrade from GM performance parts.
Old January 26th, 2010, 10:53 AM   #11
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Throw the autolites away and get some GM rapid fires.
IFS SUCKS is offline   Reply With Quote
Old January 26th, 2010, 10:54 AM   #12
wave_crusher
I'll Direc your TV
A spark plug is a spark plug, they're all pretty much the same, they wont make that big of a difference
Old January 26th, 2010, 10:57 AM   #13
IFS SUCKS
I like trees
IFS SUCKS's Avatar
I disagree GM cars and trucks hate autolites.
Old January 26th, 2010, 05:20 PM   #14
chevybtk
chevybtk's Avatar
rapid fires are junk.....lol
Old January 26th, 2010, 10:06 PM   #15
wave_crusher
I'll Direc your TV
maybe except for autolites but generally any good spark plug works just as well as the next, but i am being hypocritical because i use the diamond fires in my truck lol I like the idea that they ignite fuel better
Old January 27th, 2010, 10:17 AM   #16
chevybtk
chevybtk's Avatar
lol yeah but what kind of muffler should i put on to savor a few MPG i got a leaky glass back right now.....and never changed my o2 sensor....?
Old January 27th, 2010, 04:00 PM   #17
Disturban
Disturban's Avatar
They actually hate every spark plug but AC Delco's...I have tried every high performance plug on the market in both my Trans Am and Suburban and have always switched right back to the Delco's.
Old January 27th, 2010, 06:22 PM   #18
TeamDangerous
BUNDY HILL PIT TRASH
TeamDangerous's Avatar
One thing you should check is the coolant temp sensor. I have come across quite a few of these that have a skewed signal, meaning the sensor still works, but the resistance value may not be what it's supposed to be. So if you have the ability, check the sensor. I have changed a lot of these that have been the cause of poor mpg or driveability problems like stumbles and rough idle.
TeamDangerous is offline   Reply With Quote
Old January 27th, 2010, 08:28 PM   #19
chevybtk
chevybtk's Avatar
yeah temp sensors brand new........muffler? and like a cold air intake?
Old January 30th, 2010, 08:46 AM   #20
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
The 285's are much heavier over the stock 245's. That adds a lot more rotating weight to overcome. I've watched mileage drop on two of my trucks after going to a bigger and heavier tire. My GMC Canyon was the worst. I went from the stock 235's to a 30x9.5 LT and lost 2mpg!
Page generated in 0.55709 seconds with 83 queries
