oil change now knocks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2010, 10:04 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default oil change now knocks
94 intrepid 3.5
I have a oil leak and was getting low on oil so decided to go get an oil change. Last change was 3-4 months ago. The tech put 5 quarts in and it would not read on the dipstick. Headded one more quart and barely read. He would not add any more in fear of damaging the motor. I had this same problem last time I did the oil change but only put about 5.5 quarts in.
Next issue is as I drove away the motor knocks like hell at about 2 grand and feels real weird.
What are your thoughts as to the empty pit in my engine and the knock?
Also is there anyway to find out the correct length of the dip stick to ensure correct one.
Silver Bullet is offline   Reply With Quote
Old January 22nd, 2010, 10:07 PM   #2
kj kyle
kj kyle's Avatar
look at the base of the dipstick tube.... its prolly pressed into the block, and may have came out
kj kyle is offline   Reply With Quote
Old January 22nd, 2010, 10:31 PM   #3
MilwaukeeF350
Dan
I am sure that dipstick tube got rot and let dipstick out tube instead go in oil pan.
Just replace 1 on plow truck it 13,000 miles old engine and dipstick tube rot so bad.
Well I would go junkyard get good engine and swap that bad engine.
Old January 22nd, 2010, 10:42 PM   #4
What is the condition of the motor as far as sludge goes? If the heads are all sludged up, the oil wouldn't reach the pan very quick and give a misreading. Eventually the oil would reach the pan but it make take a few. I have had a few cars that didn't take oil for shit.
Old January 22nd, 2010, 10:46 PM   #5
Silver Bullet
The knock was not there prior to oil change and immediately after was there.
Old January 22nd, 2010, 10:48 PM   #6
Silver Bullet
I dont think it is actually that bad. Prior oil changes oil was not too bad. The engine has always had a bad bog at take off but when the bog is not there motor has alot of power.
Old January 23rd, 2010, 01:51 AM   #7
MilwaukeeF350
Dan
Could be wrong oil filter or bad oil pump or it need primer.
Can you peek in oil cap on valve cover do you see sludge or black goof inside?
Old January 23rd, 2010, 08:22 AM   #8
kkodet
kkodet's Avatar
He's right.
The problem is most likely not the dipstick, but sludge buildup in the engine. When I was working in the Chevy garage, I'd see this in older cars of every brand at least once a month.
The right way to correct the issue is to take the valve covers and intake off to clean out the buildup. However since you are already working with a $200.00 car, you can try using rislone or motor flush. I've had decent success with both.
A cheaper alternative is to put 1/2 gallon of kerosene in the oil. Run the car at idle for 5-10 minutes. DO NOT rev the engine. If it starts to make louder knocking noises, shut it off.
While the engine is still hot, drain the oil/kerosene mixture. This will flush out most everything. If you think you still have sludge, repeat the process with another 1/2 gallon and 4 quarts of oil. Do this until the oil comes out with some clarity to it. I've done this on two dodges, and it worked both times.
Old January 23rd, 2010, 10:33 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Originally Posted by keithshotrodshop View Post
He's right.
never heard of using kerosene but have heard of using ATF before with same results.
Old January 23rd, 2010, 10:46 AM   #10
greygoose
I'm the dude
greygoose's Avatar
Kerosene works better.
Old January 23rd, 2010, 10:50 AM   #11
kickstand
circling the drain
kickstand's Avatar
WTF did you just say?
I think you should sue the oil change shop, they clearly fucked something up.
Page generated in 0.24614 seconds with 56 queries
