Setting timing on a '90 FI 460 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2010, 02:28 PM   #1
Flexin' XJ
Flexin' XJ's Avatar
Default Setting timing on a '90 FI 460
I read somewhere there is a connector for the electronic timing that needs to be disconnected to stop the computer from automatically adjusting timing while trying to set base timing.
Any truth to this? Anybody know where it is?
Flexin' XJ is offline   Reply With Quote
Old January 22nd, 2010, 02:44 PM   #2
built
built's Avatar
Disconnect the single wire inline spark output (spout) connector or remove the shorting bar from the double wire spout connector located near the distributor.
built is offline   Reply With Quote
Old January 24th, 2010, 12:58 PM   #3
Flexin' XJ
Flexin' XJ's Avatar
Found it. It was nowhere near the distributor. It was on the firewall. Either way, can't set the timing since the mark on the balancer rusted away and I can't see anything resembling a mark with the timing light. Guess it is time for a new balancer too.
Old January 24th, 2010, 10:20 PM   #4
Yota Bill
sand off the balancer with a mid- to fine grade emery cloth or sandpapaer...the marks are recessed, so they will stand out when everything around them is sanded clean
Old January 25th, 2010, 04:53 AM   #5
Flexin' XJ
Flexin' XJ's Avatar
I did that. This balancer was pretty rusty so I am guessing I've lost that much metal that the marks are gone.
Page generated in 0.15034 seconds with 38 queries
