need help with a engine for my 92 chevy blazer... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 22nd, 2010, 03:12 PM   #1
chrisloco
Red face need help with a engine for my 92 chevy blazer...
need to know a 305 engine will fit in my 1992 chevy full size blazer 4x4 model k-15. original engine is a 350 5.7 liter 8 cylinder.
any help would be great
chrisloco is offline   Reply With Quote
Old January 22nd, 2010, 03:22 PM   #2
mhicks1017
mhicks1017's Avatar
you've never worked on a chevy before have you?
I laugh at beginners... Yes, that 305, 5.0 liter, V-8 will fit in the place of that 350, 5.7 liter, V-8. keep in mind that the 350 required more gas than the 305 will.
mhicks1017 is offline   Reply With Quote
Old January 22nd, 2010, 03:32 PM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Wow!!! Come on rook!!! Yes any small block will fit in there
Old January 22nd, 2010, 03:32 PM   #4
chrisloco
yea im trying to learn,just need some info gonna buy a new engine for my truck
Old January 22nd, 2010, 03:40 PM   #5
86scottsdalek10
86scottsdalek10's Avatar
You will be dissappointed with the 305. Just stick with the 350 and you won't have to mess with fuel management issues. The 350's are a dime a dozen and relatively inexpensive depending on your needs/power expectations
86scottsdalek10 is offline   Reply With Quote
Old January 22nd, 2010, 03:40 PM   #6
Hoss Blazer
!SPARTY ON!
I'd look around and see if there's some shops that sell re-man engines. Your not gonna be happy w/ a 305!! Less power, less torque than a 350!! Some shops will take your engine and sell ya a new used one! Usually w/ a warranty to!!
Old January 22nd, 2010, 03:53 PM   #7
chrisloco
thanks i will have to look into it...i need a new engine real bad and have someone for sale for $350 for a 305 and only have about $1200 to spend on one.
Old January 22nd, 2010, 04:19 PM   #8
Slayer63
Upstanding Member
Slayer63's Avatar
make sure you have the right smallblock. if you get a canadian motor you will have to swap out your steering wheel in order for it to drive on the right side of the road. and makes sure its not depressed, it make need years of therapy.
Slayer63 is offline   Reply With Quote
Old January 22nd, 2010, 04:21 PM   #9
mhicks1017
mhicks1017's Avatar
LOL!!! I thought those Canadian motors spun backwards compared to ours. If that is the case, you'll have 4 speeds of reverse, and 1 forward gear!!!
Old January 22nd, 2010, 06:48 PM   #10
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
sounds fun
you will probly not gain mileage with the 305 and you will loose power. i would just try to find a junkyard 350 with lower mile's
beaterk5 is offline   Reply With Quote
Old January 22nd, 2010, 08:00 PM   #11
Hoss Blazer
!SPARTY ON!
Where the hell are you located @?? You can look on here in the parts for sale or try craigslist as well. There some deals usually on there!
Old January 23rd, 2010, 02:44 PM   #12
chrisloco
im located in southern new mexico and i am looking around, this truck is gonna be more of a daily driver.
Old January 23rd, 2010, 02:47 PM   #13
bigbchevy
missmrgreenagain
bigbchevy's Avatar
stick with the 350
H.o.r.e
Old January 23rd, 2010, 02:59 PM   #14
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
yeah I have to agree. when I worked at the dealer back then I used to do tons of upgrade from 305s. I can't say I remember ever going backwards? if by chance you do decide to the balencer on the front and the flex plate will not be the same as a 350 so you need those. the pulleys and intake will bolt up as will the exhaust manifolds and those items. the blocks are the same all the way back to `86 so you have a lot of choices. the older ones before that will work but you have to use the old style flexplate because the crank comes out a little different. by the way your heads will bolt to any 350 or 305 block so you can reuse them if they are good.
Yetti
Old January 23rd, 2010, 03:30 PM   #15
chrisloco
Exclamation
yea im gonna have to look into junk yards and other places,need to get this truck going asap and just had a good price on that 305 with decent miles.
Old January 26th, 2010, 08:04 PM   #16
timkpetersen
Default 305 V8
Yup it is interchangeable with the 350 but you won't like the performance decrease. t
timkpetersen is offline   Reply With Quote
Old January 26th, 2010, 08:04 PM   #17
timkpetersen
Yup it is interchangeable but you won't like the decrease in performance. t
Old January 28th, 2010, 03:41 PM   #18
chrisloco
Smile
thanks for the info everyone!! just thought id say i purchased a new 350 crate engine and will be dropped in soon.
thanks for the help.
Old January 28th, 2010, 03:49 PM   #19
Hoss Blazer
!SPARTY ON!
Brand new or re-man??
Old January 28th, 2010, 03:51 PM   #20
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
You could also put a 4.3 in there with the motor mount adapters from a V6 full size truck.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Tags
305, 350, 4x4, chevy, engine
Page generated in 0.41015 seconds with 83 queries
