paint your car for $50.00 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2010, 07:42 PM   #1
yj_hank
yj_hank's Avatar
Default paint your car for $50.00
I came across this web page and I thought some of you might find it interesting. Scroll down on the thread a little and you will come across the post about the $50.00 paint job. I am thinking about doing this on my 67 f1000.
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
Henry
yj_hank is offline   Reply With Quote
Old January 21st, 2010, 07:52 PM   #2
Tom
Because racecar
Tom's Avatar
I think that guy posted that on here a while ago... He must have alot of patience.
Old January 21st, 2010, 07:54 PM   #3
cglenn
I don't know, part of me really likes that paint job, and the other part of me is a perfectionist and wants at least a half-way decent paintjob on my car. I might consider it on my dad's '33 because right now it has a Grinch-green rattle can job on it.
I wonder what that Charger looks like from a few inches or a foot away though.
cglenn is offline   Reply With Quote
Old January 21st, 2010, 08:04 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i did a ranger with rustoleum black. i sprayed the whole truck then sanded it. actually came out pretty good. cheap paint jobs can turn out quite well if you have the time and patience to do all the work.
Old January 21st, 2010, 08:09 PM   #5
BlooMule
Old School
BlooMule's Avatar
Did this with rustoleum....
Old January 21st, 2010, 08:13 PM   #6
forbyefore
forbyefore's Avatar
I used to paint my racecars with a roller... I didn't use tremclad but some kind of industrial paint my Dad would get from work. It would turn out surprisingly well. I would be leery of doing a Charger but it seemed to look pretty good for him. I would definitely practice on some stuff to get the consistency right.
forbyefore is offline   Reply With Quote
Old January 21st, 2010, 08:14 PM   #7
Trendsetter
Trendsetter's Avatar
Send a message via AIM to Trendsetter Send a message via Yahoo to Trendsetter
its called rolling and tipping. it is HUGELY time consuming!!! I have painted boats this way where you cant just stop and start. IT SUCKS!!! if done properly it looks awesome the depth of paint is great. If you go that route buy Awl-grip it even has a special thinner for doing just this job.
I think the learning curve is quicker spraying then roll and tip. plus even if you start and ground zero for spraying and have to sand and shoot two or three times you will have less time into it then roll and tip. and it is bullshit you use less paint roll and tip. I spray 3 or 4 days a week all kinds of sub-straights most can be rolled and there isn't a one yet that I don't use less paint spraying and get better coverage with
Trendsetter is offline   Reply With Quote
Old January 21st, 2010, 08:19 PM   #8
cglenn
I want that so bad. Of course I'd paint it black with the red stripe, A-team.
Old January 21st, 2010, 08:21 PM   #9
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Yeah, single stage paint is the way to go if you're on a real budget. Its just as strong as a lacquer and clear coat system, but you do not use a clear coat. That also means no fading. A lot of car manufacturers used to use this, and those paint jobs generally lasted much longer than most lacquer and clear when owned by someone who didn't really take care of them. Just all depends on the body work, how well you prep it, and you really need to spray it to get a good result.
The only problems are that you either have to strip whatever your painting to bare metal, or spray it with a sealer first. You can't paint an enamel over a lacquer paint, or it will turn out bad. I've never done it so I have no real idea what happens, but I've been warned about it.
Old January 21st, 2010, 08:29 PM   #10
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
I sprayed my civic with satin rustoleum it has a learning curve. I had lots of runs the first time and the second then I ran out of time and patience but it still looks decent at 50 feet and 50 mph. this spring it will be getting redone
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old August 22nd, 2010, 07:33 PM   #11
Blimpo
It looks great and I guarantee if you use Turtle UV inhibitor wax it will last longer than you thought. I did my putrid looking tan Ford Explorer in white employing Rustoleum mixed 50/50 with mineral spirits and a 4 inch roam roller. It's like night & day but I'm new at this and am not familiar with wet sanding. I did manage to buff it to some kind of a shine and it does look decent. I've heard stories of Rustoleum lasting over 10 years on automobiles. It also rust proofs your car at the same time. It's inexpensive and does a respectable job.
Blimpo is offline   Reply With Quote
Old August 22nd, 2010, 07:40 PM   #12
Blimpo
You have to sand it right. If you do not prepare it properly it won't take. You can always try using a $5.00 can of auto primer after you prepare it. I had t0 do that to my front hood that had lacquer on it and it took perfectly using Rustoleum.
Old August 22nd, 2010, 08:20 PM   #13
iwantawrangler
The land of Boredom..
iwantawrangler's Avatar
Send a message via AIM to iwantawrangler
im actually in the process of doing a cheap paint job on my car with tractor paint.
motivation HERE:
http://www.thirdgen.org/techboard/bo...paint-job.html
takes some time. ive got about 8 hours into this so far, but only about 50 bucks. and the car is done in primer.
and thats only because the body needed attention.
before:
after:
iwantawrangler is offline   Reply With Quote
Old August 22nd, 2010, 08:28 PM   #14
big burt
big burt's Avatar
Send a message via AIM to big burt
this wouldnt be to bad for me, but i think wet sanding can be a little tedious..can you use a d-a sander for wet sanding??
big burt is offline   Reply With Quote
Old August 22nd, 2010, 10:29 PM   #15
L4CX
Out for the Summer!
L4CX's Avatar
Wow, I might try this on my MotorCycle over the summer. Of course, that would mean I'd have to decide on a Color first.
L4CX is offline   Reply With Quote
Old August 22nd, 2010, 10:38 PM   #16
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Painted my Turbota with Royal Blue Rustoleum. Rolled on with foam roller, wet sanded between coats.
Old August 22nd, 2010, 10:57 PM   #17
iwantawrangler
you dont HAVE to use primer. depending on color. i still havent decided a color.. lol
Old August 22nd, 2010, 11:37 PM   #18
L4CX
Out for the Summer!
L4CX's Avatar
I know. I between a "School bus Yellow" that we use at the Bus garage or an orange similar to the charger. I have alot of work to do on the tank before I paint it though. It's pretty rough. I'll probably practice on a air box cover first.
Old August 23rd, 2010, 04:40 PM   #19
Chief Brody
Get off my lawn.
Chief Brody's Avatar
I did this on my Jeep. I posted some pictures a looong time ago. I thinned it out and sprayed it though. I'll see if I can find them.
Then
Now-ish
Chief Brody is offline   Reply With Quote
Old October 4th, 2010, 12:21 PM   #20
iwantawrangler
motivation HERE:
before:
after:
thought i would bump this back up. i actually painted the car finally
massey ferguson red.
Page generated in 0.50118 seconds with 82 queries
