HELP! Ford Focus Shifter Locked Up - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2010, 06:13 PM   #1
lotusexige
lotusexige's Avatar
Default HELP! Ford Focus Shifter Locked Up
Our Ford Focus's shifter keeps locking up. It did this about 2 yrs ago once and when I released it we didn't have any problems until now. There is a release next to the shifter that you push in.
Tonight it locked up every time that it was put into park. Its very difficult to release it now too.
Any ideas?
lotusexige is offline   Reply With Quote
Old January 18th, 2010, 06:34 PM   #2
lotusexige
lotusexige's Avatar
Help!!!
Old January 19th, 2010, 03:46 AM   #3
deathbypsi
Brian R.
deathbypsi's Avatar
Check to make sure your brake lites are working. If the brake light switch on the brake pedal goes out or has a bad connection it wont allow the shifter to me pulled out of park.
Seen alot of other Fords do this.
Old January 19th, 2010, 08:09 AM   #4
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
1988JeepXj is offline   Reply With Quote
Old January 19th, 2010, 09:06 AM   #5
lotusexige
lotusexige's Avatar
yep checked that.
Old January 19th, 2010, 01:34 PM   #6
ChevelleSSLS6
For Sale: AMC 360ci v8
ChevelleSSLS6's Avatar
assuming it's a slushbox, this happened to a Civic I had, I used a couple of zip ties to hold the shifter lock 'off'. Only downside is it can be moved to any gear position at any time, no brake interlock or whatever, no protection if some drunk friend tries to put it into reverse, kids playing in it, etc.
ChevelleSSLS6 is offline   Reply With Quote
Old January 19th, 2010, 02:20 PM   #7
Bones
Bones's Avatar
the brake shift interlock is just a solenoid with 2 wires (power in and ground out).
Confirm that when you are pushing on the brakes one of the wires has power, and one is grounded. If the ground wire isn't grounding,then that is a simple fix (just ground it out). If the power wire doesn't have 12V then you need to either start tracing wires, or bypass the system. An easy way to do it would be run a new wire directly off the 12V Brake On-Off switch on the brake pedal -> to the shifter solenoid.
If you have 12V and a ground and it is still locking in park, you have a bad shift solenoid, which usually means you buy a whole new shifter assembly.
The button you have been pushing to release it is the manual overide and the only reason it is there is for tow truck drivers to push before they tow the car. It isn't designed to be used a lot, usually only 10-15 times. I'm guessing the manual overide rod is worn out or broke off now.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.22833 seconds with 44 queries
