GL4x4 Live! GL4x4 Casino GL4x4 Arcade
Thread Tools Display Modes
Old January 16th, 2010, 07:33 PM   #1
Jdc215
Jdc215's Avatar
The Beast (My Little ZUK Build)
1991 Suzuki Samurai its going to fill the same role as my Bronco II but the bronco has some timing issues ill try to work on this spring and the samurai gets better fuel economy and its a manual. i like them both and both are meant to be Daily Drivers and weekend wheelers. BTW i didn't come up with the name thats what my boss calls it.
Latest Picture
stock axles
3.73 gears
Manual trans
Stock 1.3L engine
3" BDS lift springs
1.75" wheel spacers
Petroworks performance clutch
rear locker
on Road
235x75-R15 BFG track edge radials on factory wheels
off road
old 31X8-15 Goodyear Mud grip tires on 15x7 Sidekick steelies
Parts List
$1500 Samurai
$250 clutch and Bearings
$15 rear main seal
$15 Pan Ghasket
$19 Gatorback timing belt
$25 Brake pads
$60 2 Brake Rotors
$43 Brake Caliper
$37 water pump
$23 trans mount
$20 CB radio
$300 XRC8
$25 spark plugs
$40 MSD wires
$15 Dirtributor cap
$5 Distributor rotor
$200 Calimini header
$80 Hi-Lift Jack
$20 Tracker Wheels
$50 1.25" Wheel Spacers
$20 YJ Springs
$10 part of a trail tough front ML YJ kit
$22 Fuel Filter
$26 antenna
$300 winch bumper
$15 starter relay
$70 alternator
$40 alternator install kit
$25 5/8 clevis x2
$150 battery and terminals
$10 Belt
$15 brake shoes
$9 spring kit
$145 Rear Locker
$150 skid plate
$23 rear axle truss
$30 front axle truss
$40 4 u joints
$8 shackles
$8 diff caps
$35 new rear axle shafts with bearings
$8 new hardware
$160 Spidertrax HD transfer case arms
$15 wheel cylinder
$10 brake line and fittings
$200 chromolly front axle shafts
$700 4.16 transfer case rebuilt
$70 trans mount
$40 motor mount
$170 spidertrax transfer case arms
$15 transfer case mounts
$280 rear drive shaft
$230 front lock-rite
$150 front axle rebuild kit
Total Cost so Far: $5941
i just ordered a Smitty built XRC8 should be in later this week. ill be ordering a ZOR front winch bumper should have that in the next week or two. i still need to fab us some of the mounting hardware ill weld on some d-rings from tractor supply, paint it and mount up the new KC slim lights. im also planning to rig up an internal controller for the winch. im planning on putting some new shackles on to compensate for any lost ride in the front. i also have a cobra 19 ill be mounting with a wilson 3' fiberglass flex. after that ill get a belly skid, tank skid, rear bumper and Rock Sliders. finally im collecting the parts to do a YJ Missing link spring Swap. initially ill go spring under,stage 2 i will go spring over, Cromo shafts, lockers, power steering, Narrow swampers, lower gears, cage and a more powerful motor. this is all going to take place over quite a period of time but for now and probably the next few years it will stay on the 31" tires because it is my Daily Driver.
Jdc215 is offline   Reply With Quote
Old January 16th, 2010, 07:47 PM   #2
Jdc215
Jdc215's Avatar
just did the brakes today i meant to do the oil change and water pump too but my roommate left and i ended up needing a new caliper so in the end it took all day. ill do the oil and water pump tomorrow so i can go to work Monday.
Old January 21st, 2010, 03:54 PM   #3
Jdc215
Jdc215's Avatar
water pump is in and i no longer have any leaks, just got the winch today and a pay check which means im ordering the ZOR winch bumper too. should be pretty nice.
Old January 21st, 2010, 06:42 PM   #4
ZJeepMI
Rice Krispie Jeep
ZJeepMI's Avatar
Looks good, I like those little samurai's.
ZJeepMI is offline   Reply With Quote
Old February 2nd, 2010, 06:35 PM   #5
Jdc215
Jdc215's Avatar
i just did the clicky starter fix. it seems to have worked but. i wont really know until tomorrow morning when everything is good and cold. my cb antenna just came in, its a Wilson 3' Flex. my 105 AMP alternator should be in on thursday. winch bumper should be in on friday. i still need to buy a new battery, battery hold down, lights, battery clamps, alternator mounting bracket, new v-blet and an O2 sensor that ive been missing for several months now. last but not least some shackles to lift and level a little.
Old February 2nd, 2010, 08:32 PM   #6
Jdc215
Jdc215's Avatar
heres a preview of what the bumper looks like. its basically a ZOR prefab center section with rock crawler ends raised about 3/4 of an inch with some custom tabs for 3/4" d-rings.
Old February 3rd, 2010, 12:06 AM   #7
supersamikc
Yooper
supersamikc's Avatar
Send a message via AIM to supersamikc
interested in 5.13 axle gears? they helped big time on and offroad
supersamikc is offline   Reply With Quote
Old February 3rd, 2010, 12:14 PM   #8
lotusexige
lotusexige's Avatar
Little Beast. HAHAHAHAHAHAHA
More like, Little Turd.
lotusexige is offline   Reply With Quote
Old February 3rd, 2010, 12:20 PM   #9
Pokerob
hug life
Pokerob's Avatar
i like the suks more and more, nice work.
i hope your friends otherwise your an ass.
Old February 3rd, 2010, 01:47 PM   #10
creeping death
I love lamp
creeping death's Avatar
Originally Posted by Jdc215 View Post
that is a sexy bumper!
Originally Posted by MusKegon_ZJ_gurl View Post
face fucked to death by a monkey.
creeping death is online now   Reply With Quote
Old February 3rd, 2010, 04:33 PM   #11
Jdc215
Jdc215's Avatar
i never would have connected the samurai with the word Beast, but TK dubbed it and it seems to have stuck at work.
just mounted the CB radio today fit nicely on the right side of the trans tunnel and i already had a rubber grommet to run the power wires through. i think it fits nicely, now lets just hope my passengers agree. i never have to ride over there and i normally drive alone, i just hope the radio doesn't make my GF hate it more than she already does.
Old February 4th, 2010, 03:18 AM   #12
VonDirt
VonDirt's Avatar
i used to work with a guy named "tiny"
- he looked like brock lesnar.
good luck on the build
VonDirt is offline   Reply With Quote
Old February 4th, 2010, 08:55 PM   #13
Jdc215
Jdc215's Avatar
just got my alternator in today and ordered the mounting kit. ill pick up the battery, battery hold down and terminal clamps tomorrow. im going with an AMG dry vell over a Optima since i heard that optima's quality control sucks balls right now, and this battery is cheaper.
Old February 5th, 2010, 04:21 PM   #14
Jdc215
Jdc215's Avatar
today i picked up the AGM battery, battery hold down, i ordered a gatorback V-belt and the ZOR bumper arrived. ill try to get the battery in tonight, and start working on the bumper over the weekend. i initially bought the side terminal post adapters but that wont clear so ill have to get the regular flat type. i hope my GF can get me up to the auto parts so i can get the battery in.
ID:	57145   Click image for larger version
ID:	57146   Click image for larger version
ID:	57147   Click image for larger version
Old February 5th, 2010, 10:27 PM   #15
Jdc215
Jdc215's Avatar
i got the battery in the engine compartment, i had a little trouble with the connection with the fused link but after putting a new termination on i had no problems at all.everything looks good and there is plenty of room for the winch cables to attach on the top. next i need to get the alternator in and the current front end apparatus removed and make sure the frame is in suitable condition for attaching the winch bumper.
Old February 8th, 2010, 05:57 PM   #16
Jdc215
Jdc215's Avatar
i finished painting the bumper tonight and started removing that old POS on he frame but its going to be tough, whoever welded the former piece of crap on the front burned th crap out of the holes i need to mount the winch bumper. any ideas on ho to repair it a samurai frame??
Old February 9th, 2010, 03:11 PM   #17
Jdc215
Jdc215's Avatar
after looking closely at the frame and current fixture, there has been a little frame damage and its going to be more work than i anticipated but nothing unachievable, its just going to take longer. myron at ZOR was great about helping me work out a solution and he sent me some pieces of fitted steel to solve my problem for only the price of shipping.
Old February 9th, 2010, 06:19 PM   #18
cushion101990
cushion101990's Avatar
i love the bumper john
cushion101990 is offline   Reply With Quote
Old February 12th, 2010, 05:54 PM   #19
Jdc215
Jdc215's Avatar
last night i put in the GM alternator. i really hope the 105 amps will keep up with the winch. right now im just trying to find someone who can help me repair my frame so i can mount the bumper. i have that all painted and im just itching to get it all together.
Old February 14th, 2010, 10:17 AM   #20
Jdc215
Jdc215's Avatar
i mounted up the ZOR bumper yesterday. took about 6 hours of working and BSing around to get the old crap off and the new bumper on but it was fun with friends. new turn signals are in, now all i have to do is install the winch.
Thread Tools
Display Modes
Powered by: vBulletin Version 3.8.4, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ©2005 - 2009 Cracker Enterprises - Powered by Linux
Forums Directory
Page generated in 0.32747 seconds with 54 queries
