pontiac 3400 v6 problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2010, 10:53 PM   #1
RZG90
RZG90's Avatar
Default pontiac 3400 v6 problems
well my girlfriends car has some issues and although i can do some diagnosing i still wanted to have it looked at by the pros. however two different mechanics tell me two different things. one tells me the head gasket is bad and the other tells me he thinks the lower intake gasket it bad. so id like to hear some other opinions. so before it cost an arm and a leg to fix it i would like to know for sure what is wrong with it. any help would be appreciated
-symtoms.
runs like crap- pulled the code- reads cylinder 2 misfire
i replaced the plug first to see if it would make a difference and it didnt
the plug has power and spark but came out wet
the oil doesnt seem milky
i havent checked yet for pressure from the exhaust in the radiator
and it loses antifreeze
RZG90 is offline   Reply With Quote
Old January 15th, 2010, 11:17 PM   #2
ChevelleSSLS6
For Sale: AMC 360ci v8
ChevelleSSLS6's Avatar
Being a former grand am owner (3400v6, it was a 2000 grand am I souped up a bit, stock radio rims and appearance lol), if it's the heads then usually the oil would get milky.
It seems like a LIM gasket. I would go to www.gaownersclub.com (I'm a member there and visit once in a while) and get a profile and see what the guys say. I'm pretty sure there's writeups there, you don't need any super awesome special tools, just a torque wrench and basic hand tools if I remember right.
I would also run a compression test on cyl.2 and see what it runs compared to the others... and a leakdown test as well. A blown headgasket ought to show up pretty fast then!
-Matt
p.s. send me a link to the GAOC thread. Thanks!
ChevelleSSLS6 is offline   Reply With Quote
Old January 16th, 2010, 06:25 AM   #3
jbsjunk
Little Member
jbsjunk's Avatar
Does the plug smell gassy? I've seen wires go bad many times, you'll get a weak spark from the plug when checking but not enough to fire the plug when it's running.
Lower intake gaskets are very common, but they normally leak externally, usually drivers side.
At this point, I see this as two separate issues. Running rough/coolant loss. I won't rule out a bad head gasket.
Old January 16th, 2010, 06:41 AM   #4
kj kyle
kj kyle's Avatar
dex-cool?
kj kyle is offline   Reply With Quote
Old January 16th, 2010, 09:53 AM   #5
firehawk
Live Action!
firehawk's Avatar
I had to replace a head gasket on a Grand Am and it did not have milky oil.
Even if you only need to do the LIM gaskets I would go one step further and do the head gaskets as they will most likely go if they havent already and being halfway there when doing the LIM gaskets I say go for it.
Parts will be about $300-$350 iirc.
Or from what I have heard you can pick up a 3.5 from a G6, Malibu or Aura and swap it in. Then you don't have to tear the motor down just do a motor swap. And the new motors supposedly don't have the head gasket issues. The new motors can be picked up off craigslist starting at $350.
Edit: one more thing if it is a head gasket it is common for the catalytic converter to go bad during or right after a head gasket going bad.
Old January 16th, 2010, 07:15 PM   #6
frdboy
frdboy's Avatar
Does it smoke at all? Do you see any coolant leaks?
Normally if the head gasket is leaking enough to miss it will have some white smoke out the tailpipe.
I have a 5 gas analyzer at the shop and can tell you for sure if you have a head gasket leaking by checking the cooling sys. for hc's (hydrocarbons).
Check the coil for rusty terminals, also a common problem.
Page generated in 0.28365 seconds with 41 queries
