Cb Radio - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2010, 07:02 PM   #1
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Send a message via AIM to Xj Wheeler
Default Cb Radio
I have three problems. First is i bought this cheap cobra cb 40 channel from walmart for like 50 bucks. The second is i can hear people talking on it and no one can hear me WTF? i have the walkie talkie part in good and it makes a sound thing when i talk so i know it works but for some reason no one can hear me. My last problem is my antenna has cord and looks like shit with a cord running on my floor and roof of my truck.
PLEASE HELP
Xj Wheeler is offline   Reply With Quote
Old January 15th, 2010, 07:14 PM   #2
boggin-machine
boggin-machine's Avatar
Did u run it to close to the antenna? its also called a mic
Old January 15th, 2010, 07:19 PM   #3
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
no i put it on the roof but the back light on the cab. Where should it be? ill take pics if you need to see what i got going on. just let me know
Old January 15th, 2010, 08:07 PM   #4
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
^^^^^Knows CB's
Old January 15th, 2010, 08:15 PM   #5
Freak
Wheelin the HD
Freak's Avatar
did you "key up the mic" before you had the antenna plugged in? also if it has a "mic gain" knob it has to be turned all the way or most of the way to the right (clockwise).
Old January 15th, 2010, 08:16 PM   #6
boggin-machine
you cannt run power wires to close to the atena or it will screw it up
Old January 15th, 2010, 08:24 PM   #7
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
ill snap a couple pics for ya guys. give me a few minutes and come back and tell me what i should do.
Old January 15th, 2010, 08:41 PM   #8
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
heres the radio, it has volume nob, channel nob, channel 9 and 19 button, CB/PA button and scortch nob i believe is how you spell it. Also heres the cord antenna and location. i haven't mounted it yet because i might take it back if i dont get it figured out right. sorry for bad pics.
Old January 15th, 2010, 08:58 PM   #9
Freak
Wheelin the HD
Freak's Avatar
might need to adjust your antenna, and it wont work too well in your garage the guys that you can hear might have stronger radios, especially if you put it on 19 and try and get truckers.
mag mount antennas are almost idiot proof when it comes to grounding, but you still need to get the SWR adjusted... if you want to stick with a roof mount (witch is the best place to tx from) and you don't mind drilling a hole in the roof get a "gumdrop" mount, then you can run the wire over the headliner, if you go to a cb shop like the one chevyracer indicated they can help you out a lot more than anyone here can.
Old January 15th, 2010, 09:03 PM   #10
awalters
Hired Badass
awalters's Avatar
I had that problem, my radio wasn't broadcasting. The SWR might be off, but like was said before, the magnet antennas are idiot proof, or damn near it. I ran mine on top of my spare tire carrier on my Jeep, and had good luck with that.
Stick an SWR meter between the radio and the antenna and when you key it up, check what power your broadcasting at.
awalters is offline   Reply With Quote
Old January 15th, 2010, 09:05 PM   #11
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
lol yeah i know it doesnt work well in the garage. i was trying it on the road. I have yet to get a response from anyone and i know everyone cant hate me that much. they just talk back and forth and dont hear me. No way in hell im drilling any hole in the roof lol. i flinch enough drilling one under the cig lighters for the radio mount enough. i think i should take it back and buy a nicer one with like a shorter antenna that doesnt make me have to have cords hanging out.
Old January 15th, 2010, 09:06 PM   #12
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
dont make fun of me...what the hell is SWR
Old January 15th, 2010, 09:17 PM   #13
awalters
Hired Badass
awalters's Avatar
You want a longer antenna. You can probably get a bracket that mounts to your bumper or something, I have a 3 foot antenna, and I'm gonna get a 5 when I get my Jeep back home.
http://lmgtfy.com/?q=CB+SWR
Old January 15th, 2010, 09:21 PM   #14
fatboy21
Do it in the mud
fatboy21's Avatar
Send a message via AIM to fatboy21
Do like I did get a bed box and mount fire sticks(the fiberglass ones) to it. That worked a lot better for me then the mag mount.
fatboy21 is offline   Reply With Quote
Old January 15th, 2010, 09:22 PM   #15
Freak
Wheelin the HD
Freak's Avatar
sound wave reflection. its a scale to adjust your antenna length to with wavelength of the signal you are transmitting.
its a roomer that you need a good antenna to receive, any properly connected coat hanger will do, its for transmitting that you need a good antenna with proper adjustment.
that Cheap radio will do fine for about a mile, or so with a properly adjusted antenna, if you want to keep from drilling holes in the body get a fender mount that will bolt to one of the bolts in the top of the fender and come though the crack of the hood, good solid mount, good ground plane, and mostly free of obstructions.
http://s483.photobucket.com/albums/r...t=100_0312.jpg this is the one I had on my dodge, with a quick disconnect and a heavy spring that was not heavy enough for that antenna.
If you go to a radio shop, an $8 mount, $12 antenna, and $18 stretch of wire will make your install look 100x better and make that $50 radio talk. I know there are a few guys that run that radio and its not the worst thing you could buy.
Old January 15th, 2010, 09:23 PM   #16
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
i understand now. i actually just learned alot. i dont have a swr meter though :/
Old January 15th, 2010, 09:24 PM   #17
OldSlowReliable
extra on the SLOW
OldSlowReliable's Avatar
I have the same radio, and started with the same antenna as you....as I recall it worked WONDERFUL @ the dunes for listening around and to the group I was following, but I can't remember ever getting a response....possibly the antenna itself?
I got a moderately cheap (20 bucks i think?) 5ft from Flying J's and a same-grade coax cable. I haven't tuned it yet but I can easily talk to other people.....
OldSlowReliable is offline   Reply With Quote
Old January 15th, 2010, 09:25 PM   #18
fatboy21
Do it in the mud
fatboy21's Avatar
I also have a "better" Cobra CB with all the SWR, mic gain and a needle on it so mines a little easier to mess with.
Old January 15th, 2010, 09:26 PM   #19
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
yeah i think the antenna is shit. it was like 12 bucks. im going to go driving around tomorrow and see if anyone can hear me lol. i got it for the mounds and dunes. basically it.
Old January 15th, 2010, 09:27 PM   #20
Disturban
Disturban's Avatar
When you try to talk to people what do you say? Are you like saying ( This is [INSERT NAME] would someone like to talk) because maybe that's why you don't get a response. You got to talk CB lingo for example (Breaker one nine Breaker one nine, anyone have their ears on, come back) Try (Breaker 19 for a radio check) and see if you get a response.
Page generated in 0.39781 seconds with 83 queries
