Heat!!!!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2010, 09:26 AM   #1
sandunein
Default Heat!!!!!!!
hey guys. Im noticing that my heater doesnt blow air very well at all. I am going to pull the heater ducting out to check for a clog from sitting for so long but if that doesnt solve it, does anyone know of any upgrade kits for the stock heaters?
sandunein is offline   Reply With Quote
Old January 14th, 2010, 02:23 PM   #2
A4X4SPIT
A4X4SPIT's Avatar
most of the samis weve had that had weak heat turned out to be crap blocking the heater core or the linkage not opening heat flaps enuff (check this first) . Ive taken a die grinder & carefully cut a 1.5"ish slot under dash above the floor outlet in the heater box that let me get the leaves & mud out & siliconed & duct taped the new access back up ..way easier than taking it all apart to clean it up. all the samis Ive had blew great heat after
A4X4SPIT is offline   Reply With Quote
Old January 14th, 2010, 03:48 PM   #3
groundhog
groundhog's Avatar
trust him he knows........WHat up Rick!
groundhog is offline   Reply With Quote
Page generated in 0.17477 seconds with 32 queries
