70's d44 w/warns and ctms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2010, 08:05 PM   #1
TurdBronco
Default 70's d44 w/warns and ctms
I have a late 70's ford f?50 5 lug front dana 44 low pinion axle. It has warn shafts and ctm joints. 1 joint is loose and could use new bushings or let it break as they have lifetime warranties. It has 5.38 gears with a welded carrier. The long side was cut down to give the axle 63" wms to wms width. The knuckles are currently turned around to be used as a rear steer axle. It has brackets for 3 link or 4, cant remember. I will try and get pictures tomorrow.
This can be used as a front axle by turning the knuckles back around.
500 bucks obo
Old January 13th, 2010, 08:18 PM   #2
buttercr125
I work out
buttercr125's Avatar
Is the pinion centered or offset?
Old January 13th, 2010, 08:20 PM   #3
TurdBronco
offset
Old January 13th, 2010, 08:21 PM   #4
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Do you know if it's the 1978-1979 version?
brandonjb is offline   Reply With Quote
Old January 13th, 2010, 08:22 PM   #5
TurdBronco
It is not a 78-79. 77 from what I remember. It doesnt have the cast C's.
Old January 13th, 2010, 08:23 PM   #6
buttercr125
I work out
Which side is it offset to and do you have any pics of it?
Old January 13th, 2010, 08:26 PM   #7
TurdBronco
Its a drivers drop.
Its dark and cold. I will take pics tomorrow.
Old January 14th, 2010, 07:46 PM   #8
MedicJayCook
Street Doc
MedicJayCook's Avatar
i thought the 44s in the 1977 f250 where high pinion?
MedicJayCook is offline   Reply With Quote
Old January 14th, 2010, 08:26 PM   #9
Familyman
Familyman's Avatar
77-1/2 on. 76 and 77-1/2 were low pinion open knuckle disc braked.
Familyman is offline   Reply With Quote
Old January 17th, 2010, 10:57 PM   #10
TurdBronco
pics
ID:	56016   Click image for larger version
ID:	56017   Click image for larger version
ID:	56018   Click image for larger version
Old January 20th, 2010, 05:48 PM   #11
TurdBronco
ttt
i can turn knuckles around for regular front axle use
Old January 28th, 2010, 05:36 PM   #12
TurdBronco
ttt
Old February 9th, 2010, 12:38 PM   #13
TurdBronco
hi
Old February 21st, 2010, 10:17 PM   #14
TurdBronco
Old March 5th, 2010, 11:02 AM   #15
TurdBronco
ttt.
may part out?
Old March 16th, 2010, 11:09 AM   #16
TurdBronco
ttt
Old March 17th, 2010, 11:28 PM   #17
butcyh cassidy
butcyh cassidy's Avatar
would yah sell just the ctm's and everything from the knuckle out?
butcyh cassidy is offline   Reply With Quote
Old March 22nd, 2010, 03:35 PM   #18
TurdBronco
Ttt
Old March 23rd, 2010, 09:25 AM   #19
busyfixin
Balls Deep
busyfixin's Avatar
looks like a 77- f-250 dana 44 8 lug with five lug outers.
Old March 23rd, 2010, 10:59 AM   #20
TurdBronco
if 1/2 ton knuckles fit on a 3/4 ton axle, then i'd say you are right.
Page generated in 0.23059 seconds with 84 queries
