NV4500 with 6.34 creeper gear. Now with PICS!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2010, 07:58 PM   #1
v2win
v2win's Avatar
Default NV4500 with 6.34 creeper gear. Now with PICS!!!
NV4500 from a 94 GM truck with a 6.34 creeper first gear
32 spline output with round style tailhousing for NP style transfer case
No bellhousing
Model number 15960762
$1000 obo
or trade for later model GM nv4500
v2win is offline   Reply With Quote
Old January 15th, 2010, 11:00 PM   #2
v2win
v2win's Avatar
bump
Old January 16th, 2010, 04:58 AM   #3
TheresHellToPay
NotSponceredByMom&Dad
TheresHellToPay's Avatar
Mannnn if I only had the cash. :/ i want this behind my cummins so bad
TheresHellToPay is offline   Reply With Quote
Old January 16th, 2010, 01:34 PM   #4
v2win
v2win's Avatar
This has the GM style input I dont think it would work behind a cummins.
Old January 16th, 2010, 02:34 PM   #5
BigTony
Rock Rebel
BigTony's Avatar
wrong.
BigTony is offline   Reply With Quote
Old January 16th, 2010, 03:06 PM   #6
v2win
v2win's Avatar
It would work with the 5.56 first gear not the 6.34 gear I haven't been able to find one for the 6.34 first gear. If you know of someone that makes one let me know.
Old January 16th, 2010, 05:42 PM   #7
v2win
v2win's Avatar
I do know someone who has a bellhousing to adapt this to any AMC 6 or 8 engine
Old January 17th, 2010, 08:35 PM   #8
v2win
v2win's Avatar
bump
Old January 17th, 2010, 08:45 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
1200 is way too high. someone just sold one for 500 with the bellhousing and everything needed.
Old January 17th, 2010, 09:15 PM   #10
v2win
v2win's Avatar
Thats why its obo
This also has the low first gear.
Old January 21st, 2010, 09:26 AM   #11
v2win
v2win's Avatar
bump
Old January 21st, 2010, 09:51 AM   #12
kkodet
kkodet's Avatar
Originally Posted by BigTony View Post
wrong.
Actually V2WIN is right. The early GM NV4500 has a different bellhousing to trans bolt pattern than the 95-later 5.6 geared common chevy/dodge NV4500.
The only way you could mate a 92-94 GM NV4500 to a cummins is by using the very rare and expensive 3.9 Bread truck adapter. Even then the trans sits off to an angle and the slave cylinder may not clear the adapter.
Unfortunatley nobody makes any adapter bellhousings for the 92-94 GM NV4500. You are stuck with the factory stuff. I've got two of the early trans setups and wanted to mate one to my cummins. I just ended up buying a 98 Dodge NV4500 setup instead.
If you wanted the low gear behind a cummins, you would need to take the guts from this transmission and swap it into a 95 and newer case. Even then, I'm not 100% sure if this is easy or not. I do know that several NV4500 builders will do this, so it is possible.
Old January 21st, 2010, 11:41 AM   #13
ghetto fab
Yeah....That too....
ghetto fab's Avatar
Send a message via AIM to ghetto fab
hell i had mine on here for 500 and ended up sellin it for 350!! bellhousing clutch flywheel master cylinder slave cylinder and all! nobody seemed to want it so someone got a hell of a deal!
ghetto fab is offline   Reply With Quote
Old January 21st, 2010, 01:30 PM   #14
v2win
v2win's Avatar
You cant even get one from the salvage yard for that. If you can its probably junk.
Old February 3rd, 2010, 01:50 PM   #15
v2win
v2win's Avatar
bump
Old February 27th, 2010, 01:42 PM   #16
v2win
v2win's Avatar
bump
Page generated in 0.23224 seconds with 71 queries
