Remote Start Help!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2010, 05:38 PM   #1
TAZ03DAK
HA!
TAZ03DAK's Avatar
Default Remote Start Help!!!
I got a remote start for christmas, tried to install it myself and its not working correctly. A few things do work, like the lights, horn, and the first stage of ignition, but the truck wont start and door locks dont work from the remote. If anyone has experience installing these things and is looking for some extra cash (or beer) please let me know. Ive tried asking the local stores for help and either got turned away because I didnt buy it from them or because i already started the install. Its a bulldog security/remote start. and im putting it in a 03 Dakota.
TAZ03DAK is offline   Reply With Quote
Old January 13th, 2010, 06:02 PM   #2
jeepers48
jeepers48's Avatar
Maybe this guy can help you out. http://www.greatlakes4x4.com/showthr...t=remote+start
jeepers48 is offline   Reply With Quote
Old January 13th, 2010, 09:31 PM   #3
Tweeternpi
Tweeternpi's Avatar
hope this helps
Remote Start
WIRE COLOR POLARITY LOCATION
Battery PINK/BLACK OR RED (+) IGNITION SWITCH HARNESS
Ignition 1 DARK BLUE (+) IGNITION SWITCH HARNESS
Ignition 2 GREEN/RED (+) IGNITION SWITCH HARNESS
Ignition 3 RED/WHITE (+) IGNITION SWITCH HARNESS
ALL IGNITIONS MUST BE POWERED UP FOR REMOTE START
Accessory 1 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type IMMOBILEIZER (GREY KEY)
Anti-Theft Descript TRANSPONDER
Key Sense LIGHT BLUE (-) IGNITION SWITCH HARNESS
Neutral Safety DARK BLUE/YELLOW (-) AT MODULE NEAR DRIVER SHOCK TOWER - PIN #42
Tachometer BLACK/GRAY (AC) AT IGNITION COIL OR THE UNCOMMON WIRE AT THE FUEL INJECTOR.
ON THE 4.7L ENGINE, USE THE TAN COLORED WIRE AT ANY ONE OF THE COILS
Speed Sense LIGHT GREEN/WHITE (AC) IN HARNESS ON PASSENGER SIDE FIREWALL UNDER HOOD
THE PCM IS LOCATED IN FRONT OF THE WASHER FLUID RESERVOIR. THE PULSES PER MILE FOR THIS PARTICULAR VEHICLE IS 38,600
Parking Lights BLACK/YELLOW (+) AT VEHICLE LIGHT SWITCH
Brake Lights WHITE/TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights VIOLET/BLACK (+) IN HARNESS TO TRANSMISSION
ALSO AT TRAILER CONNECTOR ON EQUIPPED MODELS
Horn BLACK/RED (-) STEERING COLOMN HARNESS
Tweeternpi is offline   Reply With Quote
Old January 13th, 2010, 09:39 PM   #4
Medic8
You call, we haul.
Medic8's Avatar
If it's anything like the Ford PATS system, you'll have to take it to the dealer to have them program the remote, and you might also need a bypass for the Secure Key or Theftloc, or whatever it is that Dodge calls their system. Usually this involves an add-on module that either acts like another key.
Old January 13th, 2010, 10:06 PM   #5
TAZ03DAK
HA!
TAZ03DAK's Avatar
Originally Posted by Tweeternpi View Post
hope this helps
Remote Start
Thanks man, that should help out alot. What about the door locks? The instructions have a blue and a green that need to be connected to a wire that operates the locks.
Old January 13th, 2010, 10:51 PM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Go to the bulldog website and look up the info they have for your truck. They will have diagrams and written instructions on where to find the wires that you need.
Old January 13th, 2010, 10:56 PM   #7
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
We tried the bulldog site. The wiring diagrams they have for the model remote starter aren't the same. Like the one he has is an older version or something.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old January 13th, 2010, 11:34 PM   #8
bigblockford79
Big Block Ranger
I got mine done in my camry with the installation vid they have on the site and the vehicle wiring diagram off the site.
Old January 14th, 2010, 09:19 AM   #9
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
The Diagram On The Site Is Wrong!!!
Old January 14th, 2010, 10:20 AM   #10
Tweeternpi
Tweeternpi's Avatar
Power Unlock WHITE/GREEN (-) DRIVERS KICK PANEL
PowerLock WHITE/GREEN (-) DRIVERS KICK PANEL
Old January 14th, 2010, 11:21 AM   #11
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
One of the diagrams we found show resistors in line, we tried that and they still didn't work. I think that we may have been sending power to it not ground. Maybe that would make it work.
Page generated in 0.23360 seconds with 56 queries
