Software converting program - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2010, 10:37 AM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default Software converting program
I am looking for a program to convert a pdf into an excel spreadsheet that is functional. Any ideas? I was thinking maybe adobe suite.
Silver Bullet is offline   Reply With Quote
Old January 11th, 2010, 10:38 AM   #2
Freak
Wheelin the HD
Freak's Avatar
you might as well do it all by hand, if you make the adobe into a spreadsheet you still have to enter all the equations to make the spreadsheet work properly... Im not quite sure I understand the question.
Old January 11th, 2010, 12:23 PM   #3
Silver Bullet
I am trying to take our invoices we download off our clients websites that are pdf and convert them into an excel spreadsheet so I can sort by date.
Old January 11th, 2010, 12:48 PM   #4
SammySmalls
SammySmalls's Avatar
Sometimes the select feature will let you copy....
I dont think PDF naturally converts to xL since the value have to be separated by a comma, tab or space, which are usually annihilated as part of PDFs aim to make things uncopyable.
SammySmalls is offline   Reply With Quote
Old January 11th, 2010, 04:59 PM   #5
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
You want to merge all of the pdf's into 1 xl file or u want to make separate xl's for each pdf?
Old January 11th, 2010, 05:40 PM   #6
Silver Bullet
1-20/40 page pdf into 1 excel file.
Old January 11th, 2010, 05:45 PM   #7
Freak
Wheelin the HD
Freak's Avatar
considering a pdf is almost just an image I don't think there is anything out that does this.
Old January 11th, 2010, 05:47 PM   #8
awalters
Hired Badass
awalters's Avatar
I have two suggestions for you. 1) Try the SAVE AS TEXT option in Adobe Reader, and try importing, that into excel. I wonder what that would look like for you. I have no PDF's here to try it with, sorry.
2) Highlight everything in the PDF, and copy and paste, but do "paste special" and see if it formats it into the right columns for you.
awalters is offline   Reply With Quote
Old January 11th, 2010, 05:47 PM   #9
RyeBread
Catch the wave
RyeBread's Avatar
acrobat 8x and higher will allow you to select+copy as table and then past into excel. It will not be super clean, and it will only work if the original .pdf was generated by something 'intelligent'
if they scanned said invoices and made them into .pdf's as images then you'll have the added BS of doing OCR on those images within the .pdf
describe the order of magnitude and I'll tell you how badly you are screwed...
each page has separate headers/footers? OR is it all one 'data-dump' to .pdf?
if it's the latter, you may get lucky. I also should have said that acrobat 8x and higher will "copy-as" or "save-as" if the .pdf was created from something other than an image. e.g. - if it was created from acrobat/distiller's print-to.pdf or export-to.pdf functions.
Old January 11th, 2010, 05:57 PM   #10
Silver Bullet
To add info I am almost positive the pdf was created from some sort of invoicing program.....export as pdf.
Old January 11th, 2010, 06:02 PM   #11
RyeBread
Catch the wave
RyeBread's Avatar
the problem will be, in that many data-base based applications have horrific reporting front ends in order to make them look like their old school paper invoicing and it may not truly be a delimited file on the export.
this is seemingly especially true of older legacy type of cash receipting and invoicing systems
Old January 11th, 2010, 06:04 PM   #12
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
Have you asked whoever is doing the PDF creating if they can just export it as an Excel file for you?
mtnbikinbryno is offline   Reply With Quote
Old January 11th, 2010, 06:09 PM   #13
RyeBread
Catch the wave
RyeBread's Avatar
another thought.
if the file's creation date (from it's properties) is = to its invoice date and if these are all from the same vendor, and if all you are trying to do is sort by date, simply download them all to a new folder, and sort them via the "view-details" option in windows-file-explorer.
Old January 11th, 2010, 06:52 PM   #14
schweeb
spelling nazi
schweeb's Avatar
Originally Posted by RyeBread View Post
another thought.
This is a good point. Easier than relying on sort-by, you could come up with a file naming convention that includes a datestamp (i.e. 20090111 for today), allowing you to just sort by filename.
If you happen to be any good at programming or scripting, I'm pretty sure there are some perl or python modules that might allow you to crack it open (if the text is in a text format) and pull out some important data. Regular expressions are pretty helpful in this regard. (example: you could create a script that scans a folder, scans for a date on the invoice in the PDF, and renames the file).
Or... the best way... ask them to give you invoices in a sane format that is easy to interpret.
schweeb is offline   Reply With Quote
Old January 11th, 2010, 07:19 PM   #15
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
Plan on spending money...
http://www.pdftransformer.com/
yellowjeeperman is offline   Reply With Quote
Old January 12th, 2010, 05:51 AM   #16
SammySmalls
They are probably printing the invoice to a PDF printer, just ask them to send you the text or xL file.....
Old January 12th, 2010, 06:10 AM   #17
Silver Bullet
Come on guys thats the first thing I did. But national companies are not easy to work with. With them its survival of the fitest. This is how we do it, this is how it is to be done.....adapt...sink or swim.
Page generated in 0.34694 seconds with 73 queries
