WTB: XJ Dana 44 rear (87-89) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2010, 07:38 AM   #1
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Exclamation WTB: XJ Dana 44 rear (87-89)
Something decent and complete.
Not too worried about brakes.
Cheaper the better.
PM condition/ratio/price
SlayerXJ is offline   Reply With Quote
Old January 14th, 2010, 09:04 AM   #2
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
bUmp
Old January 22nd, 2010, 07:55 AM   #3
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
anybody?
Old January 23rd, 2010, 11:35 AM   #4
bud442
bud442's Avatar
$300, bought and never used. I will have to check for gearing. Complete but would have to have the brakes redone I am sure.
bud442 is offline   Reply With Quote
Old January 24th, 2010, 12:46 PM   #5
JERBEAR3540
Would A Rear End From A 87 Jeep Comance Work For You Give Mea Call Jerry 989588 6229
JERBEAR3540 is offline   Reply With Quote
Old January 26th, 2010, 11:49 AM   #6
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
PM sent
it would work, but it's spring under, so it would need perches welded on...
Old January 26th, 2010, 12:12 PM   #7
kkodet
kkodet's Avatar
If this is something you plan to wheel and possibly break, you may not want to go for the 44, as they are a fairly rare option, and cheap parts are not readily available.
Another option is the ford 8.8 from a 95-02 explorer. It is stronger than the 44, has the same wheel pattern, and comes with rear discs. It too will need spring perches welded on, but everything else is basically a bolt in. I just helped paintballpyscho put his rear 8.8 in his Cherokee, and it looks like it was made to be there. Plus explorer parts will be much easier to find for years to come.
Old January 26th, 2010, 12:24 PM   #8
blue thunder
blue thunder's Avatar
like stated above 8.8 is a good choise some have limited slips and come in 3.73 ratio and 4.10 explorers are spring under and rangers are spring over most explorers have rear disc as an option. rangers do not.
blue thunder is offline   Reply With Quote
Old January 27th, 2010, 09:22 AM   #9
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I've researched the 8.8 option.
I don't like that they're shorter than stock width.
Parts seem to be equal in price vs. 44 and more options for the 44.
I don't want to screw with welding mounts, but for cheap i'd consider an MJ axle...
I know they're rare on xj's, but people have them.
Old January 27th, 2010, 11:11 AM   #10
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I've got one that I will be selling in a month or so, once I've finished building it's 8-lug replacement.
3.55 gears, welded diff, heavy chrome cover, newer brakes, wheel seals, heavy duty high clearence XJ shock mounts.
I was thinking I'd offer it up for $300 when I take it out, but the Jeep doesn't run, so I may be persuaded to pull it and sell it before I'm ready for a few more $$ or a bolt-in axle that I can roll it around on.
Old January 27th, 2010, 11:17 AM   #11
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
WRONG; the axle is rare but it shares the same internals as the tj 44, so shafts are easy to come by and 44 gears and lockers are everywhere. You can also do a disc brake swap using zj parts for fairly cheap.
Page generated in 0.25907 seconds with 56 queries
