semi-wrenchie: need help this sunday, 7/23!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Meets, Greets, and Wrenching
Old July 18th, 2006, 02:26 PM   #1
tonybalido
Loser4Life
tonybalido's Avatar
Send a message via AIM to tonybalido Send a message via MSN to tonybalido
Unhappy semi-wrenchie: need help this sunday, 7/23!!!
I hope I don't get flamed for this, but I need an extra hand to work on my wife's 00' beetle. It wouldn't start this morning, and I'm 85% sure its timing belt failure. I'm going to run the codes and trial and error through everything I can think of. I need help because unlike every other car on earth, the new beetle's timing belts can only be replaced if the engine is off one of its mounts.
And 2-8 heads is better than just my one. Sometimes.
Any help is appreciated.
Sterling heights anyone???
tonybalido is offline   Reply With Quote
Old July 18th, 2006, 06:39 PM   #2
tonybalido
Loser4Life
tonybalido's Avatar
Well, its not the timing belt. Its some other whirring noise... maybe the coil pack. So now that its not the timing belt, I don't think I'll need help on Sunday. Well, I hope not. I'm still surfin forums to figure this out...
Old July 18th, 2006, 06:47 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
You still need help? I'm 10 minutes north of you. I can help ya out tonight if you want.
Old July 18th, 2006, 06:48 PM   #4
GreaseMonkey
Pew pew!
Whirring noise when you try to start it? So I'm assuming it's not cranking, you just turn the key and here the whirring noise. If that's the case, it's the starter solenoid. You may be able to get just the solenoid, but it's easier just to get the whole starter and replace it.
Old July 18th, 2006, 07:48 PM   #5
tonybalido
Loser4Life
tonybalido's Avatar
Whoops, need to clarify that whirring noise... that noise is after it cranks. cranks and cranks, but wont turn over. then i'd quicky stuff my head back in the engine compartment and hear that lil whirring noise. like a housefly type noise.
Old July 18th, 2006, 08:43 PM   #6
GreaseMonkey
Pew pew!
Hmm....will you be at home around 6:30 tomorrow? I can stop by after work and check it out. Shoot me a PM with your #.
Old July 18th, 2006, 08:51 PM   #7
tonybalido
Loser4Life
tonybalido's Avatar
sent
Page generated in 0.18878 seconds with 44 queries
