NkLgIgL ReBuIld - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2010, 12:28 PM   #61
jeepyj93
Sundowner
jeepyj93's Avatar
I will eventually replace the seats with some suspension seats. I just don't have the money. And these clean up alot easier from the mud. The pads/covers that I have for them are pretty nice. The seats actually fit how my back is shaped, So they are comfortable to me. Some others don't like them as much, but I don't see them pulling out their credit cards for a new set. Lol.
jeepyj93 is offline   Reply With Quote
Old July 27th, 2010, 12:54 PM   #62
jeepyj93
Sundowner
jeepyj93's Avatar
Working on pulling the rear suspension today. Going to rebuild the rear springs, and put some non welded spiders in the diff for now since it will be getting driven on the road for a while. Also have a new lube locker gasket for the rear.
Old July 28th, 2010, 10:56 AM   #63
jeepyj93
Sundowner
jeepyj93's Avatar
Here is the list that I started with. got a majority of this stuff done. Now I have some stuff that isn't on the list. But mostly little odds and ends.
* Ford 8.8 -lines,calipers, and pads
* Cut and drill t/case output
* Swap XJ D30-perches, rebuild, gears, shafts
* valve cover gasket
* coolant
* refill transmission and t/case
* rebuild front spring packs-clean, and paint
  • rebuild rear leaf springs.
* CJ hood and grill swap
* Build new tube fenders
* rear shocks & mounts
* tranny mount
* trim the skidplate
* tie-in the cage to the frame
* add on to cage
* mount seats to cage
* clearance explorer rims to clear hubs
* install winch power disconnect
* build rear driveshaft
* rebuild steering linkages
* new u-bolts for front axle
* paint
* bedline inside
* build radiator cover
Old July 28th, 2010, 12:06 PM   #64
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
you have come a long way, keep it up, mine hasnt been out of the barn in 2 1/2 years.
jeepster95 is offline   Reply With Quote
Old August 3rd, 2010, 08:49 PM   #65
jeepyj93
Sundowner
jeepyj93's Avatar
Got some stuff done today. I got the shackles cleaned up and repainted, the spring all ground down and have one coat of fresh paint on them now. Gonna finish them tomorrow and then put them back together. The front axle is ready to go in, and get the perches welded up. The rear axle is ready to go in, and have perches welded. Also got the shifter/boot/knobs put back together. I also got the gas tank fastened down. Hopefully getting a bit more stuff done tomorrow.
Next big project is figuring out the steering. Trying to decide if I want to use stock stuff for now to get it running, or just take some more time and build a custom setup.
Also planning on getting rear shaft welded up this weekend, or beginning of next week.(my welder is currently out of town. LOL)
I will post some new pictures when I get a little bit more done.
Old August 5th, 2010, 12:33 AM   #66
Offroadian
seasoned
Starting to take shape!
Offroadian is offline   Reply With Quote
Old August 5th, 2010, 09:47 AM   #67
ccidriveline
ccidriveline's Avatar
Originally Posted by jeepyj93 View Post
Right now I have the jeep sitting SOA in the rear, but it is a little higher than I would like, so I am going to stick with the SUA front and rear, and around a 3" lift. I have the wheelbase at 102". 35" Trxus STS on explorer wheels. Working on DIY SYE. And YJ hood and grill are off, waiting for the CJ hood and grill.
Here is a list of the things that I still have to do, or am in the process of doing.
  • Ford 8.8 -lines,calipers, and pads
  • Cut and drill t/case output
  • Swap XJ D30-perches, rebuild, gears, shafts
  • remove cage mount spacers
  • valve cover gasket
  • coolant
  • refill transmission and t/case
  • rebuild spring packs-clean, and paint
  • CJ hood and grill swap
  • Build new tube fenders
  • rear shocks & mounts
  • tranny mount
  • trim the skidplate
  • tie-in the cage to the frame
  • add on to cage
  • mount seats to cage
  • clearance explorer rims to clear hubs
  • install winch power disconnect
  • build rear driveshaft
  • rebuild steering linkages
  • new u-bolts for front axle
  • paint
  • bedline inside
  • build radiator cover
We build new driveshafts for Jeeps if you like call CCI Driveline 586-716-1160.
ccidriveline is offline   Reply With Quote
Old August 6th, 2010, 04:34 PM   #68
jeepyj93
Sundowner
jeepyj93's Avatar
Got the gears in the rear axle swapped around and the new LubeLocker gasket installed. Put the rear axle back in the jeep, and bolted everything together. I still need to get some U bolts for the front on monday so that I can bolt the front axle in place, and have it setting on it's own weight so that I can set the pinion angles. I put the rear tires on, and I forgot how good it looks. I can't wait to get the front end back together. I will get some pics when I get some stuff moved around the in the barn later.
Old August 6th, 2010, 05:24 PM   #69
89cjwftw
jeeprbrown
89cjwftw's Avatar
lookin good
89cjwftw is offline   Reply With Quote
Old August 8th, 2010, 10:18 PM   #70
jeepyj93
Sundowner
jeepyj93's Avatar
I got the front u joints done today. Found some clean turn signal lenses off an old CJ in the junkyard today. Just need to find some axle shaft slingers, and get a new unit bearing, and the front axle will be back together. Hopefully getting some u bolts for the front tomorrow, and I can get it back on all 4 tires.
Old August 9th, 2010, 10:50 PM   #71
jeepyj93
Sundowner
jeepyj93's Avatar
Here are some current pic of how the jeep sits as of this evening. I really liek the new stance, and lift height. I also think I did pretty good just guessing on the leaf springs when building my first set of bastard packs. Hopefully knocking out some more stuff tomorrow.
Old August 19th, 2010, 11:32 PM   #72
jeepyj93
Sundowner
jeepyj93's Avatar
Got the axles back today from having a friend weld the spring perches, and weld the 8.8 axle tubes to the differential. Threw a coat of gloss black on them to make them look a little better. Getting the axles back in tomorrow, then working on getting the brakes back on, new lines ran, and bleeding them, getting the fluids filled, tires back on, getting the driveshaft setup for the rear, and any other little projects that I find once that stuff is done.
Old August 21st, 2010, 10:05 PM   #73
jeepyj93
Sundowner
jeepyj93's Avatar
Got the axles in, differentials and transmisssion filled, brakes on( started to bleed but I found a bed caliper, and getting a new one in the morning.)finishing up most of the little stuff tomorrow. Then just need to build steering linkages, rig some form of exhaust and get the rear drive shaft welded up. Hoping to have it running for a test run around the yard monday night or tuesday. I will get some pics on its maiden voyage out of the barn.
Old August 24th, 2010, 09:15 AM   #74
jeepyj93
Sundowner
jeepyj93's Avatar
Here are some new pics of the jeep.
Old August 24th, 2010, 10:30 AM   #75
79f150stepside4x4
WOW This has come along way since I was on here last.
79f150stepside4x4 is offline   Reply With Quote
Old August 24th, 2010, 04:35 PM   #76
drew91xj
drew91xj's Avatar
looks really nice
Old August 24th, 2010, 09:19 PM   #77
jeepyj93
Sundowner
jeepyj93's Avatar
It is running now. Just need to get the air out of the cooling system, and then get the inserts for the steering so that I can get that finished. Then weld the rear driveshaft and put it in. I am ready to drive it.
Old August 28th, 2010, 06:19 PM   #78
jeepyj93
Sundowner
jeepyj93's Avatar
The steering linkages are ready to be welded, as is the rear driveshaft. Getting them welded, then installing them. And hopefully driving the jeep soon.
Old August 30th, 2010, 10:37 PM   #79
jeepyj93
Sundowner
jeepyj93's Avatar
The jeep went up and down the road tonight under its own power. Now I need to work on the bumpstops, steering stops, and shock mounts. At least it is running now. Just little things now, Finally.
Old September 5th, 2010, 10:27 PM   #80
jeepyj93
Sundowner
jeepyj93's Avatar
Been working on little things lately but nothing that is worth taking pics of. Trying to decide how to mount the rear shocks. There isn't enough room between the frame and inside of the tires. Thinking about mounting the top of the shock near each other, and having them angle out to the bottom mounts out near the leaf springs. I know this isn't the greatest way, since the shocks will not work the best, but I dont see any other options. If you have any ideas let me know. I will try to get some pics up so that it is easier to explain.
Page generated in 0.55821 seconds with 83 queries
