700R4 and 231c SOLD***SOLD***SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2010, 10:26 PM   #1
low900rr
low900rr's Avatar
Default 700R4 and 231c SOLD***SOLD***SOLD
Bought this combo to put in my TJ behind a V8. Its the 231c so its drivers side output for the front driveshaft. Has the tcase shifter already built in to the setup so you dont have to worry about making a tcase shifter linkage. I paid $350 for the setup, like to get $300 out of it. Comes complete all bolted together with torque converter.
low900rr is offline
Old January 7th, 2010, 06:52 AM   #2
rangell
Ma' Meatloaf
rangell's Avatar
pm sent
rangell is offline
Old January 7th, 2010, 07:11 AM   #3
low900rr
low900rr's Avatar
returned
low900rr is offline
Old January 7th, 2010, 08:20 AM   #4
rinking
rinking
Is the t-case a 231c-HD?
rinking is offline
Old January 7th, 2010, 08:44 AM   #5
low900rr
low900rr's Avatar
not sure
low900rr is offline
Old January 8th, 2010, 06:34 AM   #6
rinking
rinking
I'm looking for a 231c/hd for My v-8 swap. It should say on the transfer case tag if it is a "hd". thanks
rinking is offline
Old January 8th, 2010, 06:58 AM   #7
knaffie
knaffie's Avatar
like this
knaffie is offline
Old January 8th, 2010, 11:41 AM   #8
low900rr
low900rr's Avatar
Since its from an s10 blazer im sure its not the HD. The HD's are probably from the 3500 IFS fullsize trucks. Whats different about em a wider chain inside???
low900rr is offline
Old January 8th, 2010, 11:44 AM   #9
knaffie
knaffie's Avatar
WRONG! That picture I posted is from a 1992 S10. All the HD marked cases will have the 1.25" wide chain and gears. Sometime around 1995, they stopped putting the 1.25" wide chain in the S10 cases and went to a 1" wide chains. The 231C-HD has the same planetaries and chain width as the fullsize 241. In fact, that 6 pinion planetary set is the same one they use in the Klune V, Atlas 4 speed, and NWF black box. Its WAY overkill for the 231 case.
EDIT: On the pre-1995 S10 cases, most of them have the HD parts, even though they are not all marked with the HD stamp.
knaffie is offline
Old January 8th, 2010, 12:01 PM   #10
low900rr
low900rr's Avatar
mine is not stamped HD
low900rr is offline
Old January 8th, 2010, 12:08 PM   #11
knaffie
knaffie's Avatar
So the only way to tell for sure is to open it up and see if it has the HD stuff. Its its pre-1995, chances are it does. The HD is just helpful because you know for sure if it has the HD components inside or not.
knaffie is offline
Old January 8th, 2010, 12:13 PM   #12
low900rr
low900rr's Avatar
this is from a 92
low900rr is offline
Old January 9th, 2010, 07:12 AM   #13
low900rr
low900rr's Avatar
bump.........$250 if someone wants to grab it today
low900rr is offline
Old January 11th, 2010, 08:08 AM   #14
low900rr
low900rr's Avatar
back up
low900rr is offline
Old January 12th, 2010, 07:41 PM   #15
low900rr
low900rr's Avatar
The trans is a "K" case someone needs this for a wrangler
low900rr is offline
Old January 13th, 2010, 07:20 PM   #16
8737weaver
I drank the blinker fluid
8737weaver's Avatar
how many miles are on the trans? any pics?
8737weaver is offline
Old January 14th, 2010, 03:14 PM   #17
low900rr
low900rr's Avatar
I cant say for sure how many miles are on it.........do know it works and shifts fine. Ill get some pics tonight if I go out in the garage.
low900rr is offline
Old January 14th, 2010, 08:19 PM   #18
snow fighter
any takers yet, I need this for my yj. could come and get it this weekend. feel free to call me @ (586) 634-3743
snow fighter is offline
Old January 15th, 2010, 12:10 AM   #19
low900rr
low900rr's Avatar
come and get it!!!! want it out of the garage
low900rr is offline
Old January 15th, 2010, 03:12 AM   #20
snow fighter
coo l give me a shout later to let me know where I am going.
Page generated in 0.43839 seconds with 83 queries
