timing a 5.4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 11:45 PM   #1
masterbeatty
masterbeatty's Avatar
Default timing a 5.4
does anyone here know how to properly time a 5.4 triton? and if so can i get some help please?
Old January 6th, 2010, 06:18 AM   #2
Medic8
You call, we haul.
Medic8's Avatar
You don't. If your timing is off, it's because you somehow jumped a tooth on your timing belt/ chain (can't remember which it is, offhand). The 5.4L engines are either coil on plug, or with a coil pack, so there's no distributor to time.
Edit: This is for every 5.4L I've seen, which is only 99 and up. Granted the earlier ones could have had a distributor, but I don't think so. If you post up the year and make that the engine is in, I'll look in the Tech website here at work and see if there's anything listed.
Old January 6th, 2010, 06:20 AM   #3
boggin-machine
boggin-machine's Avatar
x2
what makes you say its off time?
Old January 6th, 2010, 06:33 AM   #4
greygoose
I'm the dude
greygoose's Avatar
I don't even see how it could have jumped time with the automatic chain tensioners mod motors have.
Old January 6th, 2010, 10:52 AM   #5
masterbeatty
sorry guys im putting a motor together for the truck. my oil pump failed on the previous motor so i pulled it. im not sure how to time the cams right. everything i read honestly confuses me.
Old January 6th, 2010, 11:09 AM   #6
MidMichxj
Wrenchin for a livin
MidMichxj's Avatar
You have the special tool kit, correct? If not it is almost impossable to get them correct (tried that).
MidMichxj is offline   Reply With Quote
Old January 6th, 2010, 11:42 AM   #7
masterbeatty
no are you talking about that kit that is like 500 bucks?
Old January 6th, 2010, 12:32 PM   #8
TeamDangerous
BUNDY HILL PIT TRASH
TeamDangerous's Avatar
You shouldn't need the kit that is $500 unless you have dual cams. The other set I believe is about $125 from OTC. However, I think I have seen it in the loan-a-tool selection at autozone.
TeamDangerous is offline   Reply With Quote
Old January 6th, 2010, 02:16 PM   #9
Medic8
You call, we haul.
Medic8's Avatar
I just looked up the proceedure and it looks like you'll definitely need that tool set. I looked up the 5.4L 2V engine from a 99 Expedition, just to give you an idea. Here's a copy/ paste of the instructions, just in case it'll help. No pictures, unforunately.
Installation
CAUTION: Timing chain procedures must be followed exactly or damage to valves and pistons will result.
CAUTION: Do not compress the ratchet assembly. This will damage the ratchet assembly.
Compress the tensioner plunger, using an edge of a vise.
Using a small screwdriver or pick, push back and hold the ratchet mechanism.
While holding the ratchet mechanism, push the ratchet arm back into the tensioner housing.
Install a paper clip into the hole in the tensioner housing to hold the ratchet assembly and plunger in during installation.
Remove the tensioner from the vise.
If the copper links are not visible, mark one link on one end and two links on the other end, and use as timing marks.
Install the timing chain guides.
CAUTION: Do not turn the engine over with the camshaft positioning tool or damage to the camshaft sprocket or the bolt may occur.
Install the Camshaft Positioning Tool.
Slightly loosen the camshaft holding tools to allow slight camshaft movement. Rotate the LH camshaft with the Camshaft Positioning Tool until the timing mark is approximately at 12 o'clock.
Rotate the RH camshaft with the Camshaft Positioning Tool until the timing mark is approximately at 11 o'clock. Tighten the Camshaft Holding Tools to maintain camshaft pre-positioning.
CAUTION: Unless otherwise instructed, at no time when the timing chain/belts are removed and the cylinder heads are installed is the crankshaft or camshaft to be rotated. Severe piston and valve damage will occur.
CAUTION: Rotate the crankshaft counterclockwise only. Do not rotate past position shown or severe piston and/or valve damage can occur.
Position the crankshaft with the Crankshaft Holding Tool.
Remove the Crankshaft Holding Tool.
NOTE: Crankshaft sprockets are identical. They may only be installed one way. Refer to the following illustration for correct crankshaft sprocket installation.
If removed, install the LH and RH crankshaft sprockets.
Install the LH timing chain onto the crankshaft sprocket, aligning the one copper (marked) link on the timing chain with the slot on the crankshaft sprocket.
NOTE: Make sure the upper half of the timing chain is below the tensioner guide dowel.
NOTE: If necessary, adjust the camshaft sprocket slightly to obtain timing mark alignment
Position the LH timing chain on the camshaft sprocket with the two copper (marked) chain links and the camshaft sprocket timing mark aligned.
Position the RH (outer) timing chain on the crankshaft sprocket, aligning the copper (marked) link with the timing mark on the sprocket.
NOTE: If necessary, adjust the camshaft sprocket slightly to obtain timing mark alignment with the Camshaft Positioning Tool.
Position the RH timing chain/belt on the camshaft sprocket. Make sure the two copper-colored links align with the camshaft sprocket timing mark.
Position the LH and RH timing chain tensioner arms on the dowel pins. Position the timing chain tensioner assemblies, and install the bolts.
Remove the pins from the RH and LH timing chain tensioner assemblies.
Remove the Camshaft Holding Tool.
As a post-check, verify correct alignment of all timing marks.
Position the crankshaft sensor ring on the crankshaft.
Apply a bead of silicone along the head-to-block surface and the oil pan-to-block surface as specified.
Use Silicone Gasket and Sealant F6AZ-19562-AA or equivalent meeting Ford specification WSE-M4G323-A6.
Install the engine front cover; refer to Engine Front Cover—5.4L in this section.
Old January 6th, 2010, 03:14 PM   #10
Yota Bill
if you cant find the tools in one of the parts stores loaner programs, I have my own. let me know if you need them.
Old January 28th, 2010, 05:44 PM   #11
masterbeatty
is there anyone here that has a factory ford service manual?
Old January 28th, 2010, 07:57 PM   #12
7.3X
Fullsize support vehicle
7.3X's Avatar
Manuals we don't read no stinkin manuals
7.3X is offline   Reply With Quote
Old January 28th, 2010, 10:25 PM   #13
masterbeatty
i no we need the dude named manwell
Old January 31st, 2010, 02:48 AM   #14
Fraser
Fraser's Avatar
i think my uncle is selling his 5.4 timing setup w/e tool it is, i can check into it if you may be interested.
edit- or contact warner on here, its his dad that has it
Old February 1st, 2010, 09:02 AM   #15
masterbeatty
thank you i have a guy thats supposedly going to time it for me but if that falls through i will get ahold of him,
Page generated in 0.37431 seconds with 68 queries
