dana 30 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 04:02 PM   #1
cgarbo
HILLJACK DESIGN'S
cgarbo's Avatar
Default dana 30
i need a complete dana 30 axle
cgarbo is offline   Reply With Quote
Old January 5th, 2010, 04:04 PM   #2
All5ofus
All5ofus's Avatar
Does it need to be out of anything to match up or is any D30 fine? Also what gearing are you looking for?
All5ofus is offline   Reply With Quote
Old January 5th, 2010, 04:07 PM   #3
cgarbo
HILLJACK DESIGN'S
cgarbo's Avatar
no i just need a dana 30 and ill re-gear it
Old January 5th, 2010, 04:10 PM   #4
jon_xj90
fake it till you make it.
jon_xj90's Avatar
no he means, do you need a...
cj pass drop 30 with 5x5.5bp for leaf springs?
xj drivers drop disco axle for coil spring?
xj drivers drop non disco axle for col spring?(same as tj)
yj drivers drop disco axle leaf spring setup?
zj drivers drop with cv yoke?
what gears are you putting in it so what carrier do you need?
complete axle assembly or just a housing? be specific man. lol
jon_xj90 is offline   Reply With Quote
Old January 5th, 2010, 11:01 PM   #5
warner
oops, shit happens.....
warner's Avatar
iv got one its a low pinion
warner is offline   Reply With Quote
Old January 6th, 2010, 06:48 AM   #6
cgarbo
HILLJACK DESIGN'S
cgarbo's Avatar
i dont really know what one i need its gonna be used to do a leaf spring sas on a gmc sonoma.
Old January 6th, 2010, 07:14 AM   #7
jon_xj90
jon_xj90's Avatar
ok then first things first. what rear axle are you running? (to try to match the bolt pattern since that is a 5x4.75 and most d30s you'll find are 5x4.5. if it's pass drop you can use a cj axle and get the benefit of lockouts. what side drop do you need we can figure out what jeep in needs to have come out of.
Old January 6th, 2010, 09:15 AM   #8
dmcjeep
dmcjeep's Avatar
I would nat say "most" dana 30's that you find are 5 x 4 1/2. CJ dana 30's were all 5 x 5 1/2 and there are a hell of a lot of them out there. I have both wide and narrow CJ ones that I would sell for $75 each.
dmcjeep is offline   Reply With Quote
Old January 6th, 2010, 09:30 AM   #9
cgarbo
HILLJACK DESIGN'S
cgarbo's Avatar
driver drop and the spacing is 5-4.75
Old January 6th, 2010, 09:56 AM   #10
dmcjeep
dmcjeep's Avatar
I have a complete one from a YJ with 3:73 gears $100
Page generated in 0.45485 seconds with 53 queries
