Engine restore, does it really work? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 04:23 PM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default Engine restore, does it really work?
Does using Engine Restore actually do anything for an engine with high mileage?
I have a Chevy S10 with 200k that smokes a little bit and someone told me to try adding some Engine Restore (at least I think that's what he said it was called) to the oil.
chevyk10 is offline   Reply With Quote
Old January 5th, 2010, 04:37 PM   #2
mudbillyredneck
mudbillyredneck's Avatar
I've torn one appart that had that stuff run threw it 10,000 miles before I got my hands on it....didnt see any evidence it did anything..except gum up the oil pickup screen alittle
Thats's just my 2 cent's
mudbillyredneck is offline   Reply With Quote
Old January 5th, 2010, 04:42 PM   #3
TeamDangerous
BUNDY HILL PIT TRASH
TeamDangerous's Avatar
Have you tried running a heavier weight oil first? Engine Restore is basically 30wt oil with CSL (Copper Silver Lead), similar to Anti-Seize. The concept is that the CSL will fill in the scratches and whatnot in the cylinder walls to help seal the rings better. I have heard of it working in some cases, but I certainly wouldn't trust it in anything of mine.
TeamDangerous is offline   Reply With Quote
Old January 5th, 2010, 04:42 PM   #4
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
my theory is you can't replace metal with a liquid. just my $.02.
hawkscj5 is offline   Reply With Quote
Old January 5th, 2010, 04:47 PM   #5
chevyk10
FORD / GM
chevyk10's Avatar
Yeah, I say the same thing. But it could still work as a temporary fix though...
Old January 5th, 2010, 05:02 PM   #6
jon_xj90
fake it till you make it.
jon_xj90's Avatar
smokes a little bit when? all the time or just when started? could be valve seals. and what engine is it? a 4.3L?
jon_xj90 is offline   Reply With Quote
Old January 5th, 2010, 05:09 PM   #7
devox
devox's Avatar
I have ran it in a 260,000 mile 6.9 diesel, It WORKS and has been for 5 years.
If I go a few oil changes with out it the truck starts smoking bad again.
Try it and report back.
devox is offline   Reply With Quote
Old January 5th, 2010, 05:46 PM   #8
chevyk10
FORD / GM
chevyk10's Avatar
It gets pretty smokey when you first start it, then its not as bad when it warms up. And yes 4.3.
Old January 5th, 2010, 05:50 PM   #9
chevyk10
FORD / GM
chevyk10's Avatar
Never heard of a diesel smoking at 260k miles. I don't know how well those older diesels are built or how long they usually last though, but I have a friend with a 91 F350 7.3 liter with 400K + miles and it still runs strong.
Old January 5th, 2010, 05:53 PM   #10
jon_xj90
jon_xj90's Avatar
i was going to comment on that also, 260k sounds a little light for your diesel to be smoking, if anything i think that restore is too light compared to diesel oil isn't it?
and i don't know what this will really do for you (if it were to do anything in the first place), if your issue isn't necessarily rings and scored cylinder walls.
Old January 5th, 2010, 05:55 PM   #11
Nuggets
I fix stuff!
Nuggets's Avatar
The only pour in product that I've found that does anything is Lucas.
Old January 5th, 2010, 06:03 PM   #12
TeamDangerous
I don't think the Engine Restore is going to restore your valve seals. I am going to recommend the Lucas as well. Also try running 15w40.
Old January 5th, 2010, 06:04 PM   #13
chevyk10
FORD / GM
chevyk10's Avatar
Just found this site on Lucas oil:
http://www.lucasoil.co.uk/products.p...uct&product=12
Thanks, I think I'm gonna give that a try instead.
Old January 5th, 2010, 06:52 PM   #14
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I heard that Engine Restore had junk like wax in it or something to that affect. Never used it, and just by the looks of it I'd never want to pour it into my oil fill cap. I bet all it does is thicken up the oil to help raise compression. The whole advertising it fills in wear on the cylinder is absolute bullshit.
Lucas makes great products, and the only other additive that works good is Seafoam but isn't for raising the compression.
Interesting link I found too: http://www.carbibles.com/additives.html
Old January 5th, 2010, 07:01 PM   #15
booblinker
Sore and Tired 24/7
booblinker's Avatar
I'd go with some lucas, great product, with a lot more R&D behind it.
booblinker is online now   Reply With Quote
Old January 5th, 2010, 07:25 PM   #16
devox
devox's Avatar
Dedicated tree farm truck, Has been ran hot countless times due to careless non caucasians driving branches through the radiator. For Worn cylinders and scored rings, Restore does work.
Old January 5th, 2010, 07:28 PM   #17
ffjosh
Are you talking about the stuff in the chrome bottle you can get at Autozone?
I tried it in my old GEO with 140,000. It was hard to tell if it worked or not. I used it for a while and seen not results, stop using it and it seemed to start getting worse mileage. could be my bad math lol
Its cheap, so I would try it
ffjosh is offline   Reply With Quote
Old January 10th, 2010, 06:59 AM   #18
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
If the engine is that loose, run straight 30 or 40 weight. I've used the Restore stuff on my beaters when I was a kid and it never improved anything for me.
Page generated in 0.56645 seconds with 77 queries
