Dana 60 lockout hitting the spindle. - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 02:12 PM   #61
jon_xj90
fake it till you make it.
jon_xj90's Avatar
an inner race not being fully seated would help him in this situation, not create the problem. he needs the hub to protrude further out past the spindle than it currently is to get the lockout to fully install.
i've had 10 bolts, 44s, and 60s apart before but never really had an issue putting them back together so i may sound dumb or this may be reasonable but..
how similar in diameter and profile are the inner and outer bearings?
jon_xj90 is offline   Reply With Quote
Old January 5th, 2010, 03:03 PM   #62
Sandals
Fucking Zen as Shit
Sandals's Avatar
Did he install bearing races???
that would cause it to sit incorrectly
Old January 5th, 2010, 03:14 PM   #63
Eric99tj
Just bump it....
Eric99tj's Avatar
Check the inner wheel bearing and race. There is different ones to offset the hub differently. That would be my guess.
Eric99tj is offline   Reply With Quote
Old January 5th, 2010, 03:52 PM   #64
I'm 5 minutes from Jeff's Bronco Graveyard if you need anything. I charge a 25% upcharge for delivery.
Old January 5th, 2010, 03:54 PM   #65
jon_xj90
jon_xj90's Avatar
i know there is a narrow race that is supplied with some 35 spline kits that account for c-clip and shaft length. maybe you have one and need the other? just a thought to piggy back eric99tj's
Old January 5th, 2010, 04:43 PM   #66
Eric99tj
Just bump it....
Eric99tj's Avatar
382A is the correct inner race but if for some reason you needed more room for your lockout you can use a 382S race and it will bring the hub 1/8" outward.
Old January 5th, 2010, 05:01 PM   #67
bigbchevy
missmrgreenagain
bigbchevy's Avatar
jim your a big help lol
Old January 5th, 2010, 06:39 PM   #68
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
OK- it's almost 8PM What's the judgement????
Old January 5th, 2010, 06:43 PM   #69
Sandals
Fucking Zen as Shit
Sandals's Avatar
Weld it in place?
Old January 5th, 2010, 06:44 PM   #70
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Originally Posted by Sandals View Post
Weld it in place?
NICE!!!! FTW!
Old January 5th, 2010, 07:15 PM   #71
Renegade II
Coil springs are for pens
Renegade II's Avatar
I have a complete 79 F350 SRW 60 front if you get desperate enough to drive this far.
Old January 5th, 2010, 08:00 PM   #72
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
CC, i have some spare dana 60 parts if you need something
I'm the man in White.
Old January 6th, 2010, 06:24 AM   #73
clarkstoncracker
lol
clarkstoncracker's Avatar
After having five knowledgeable people look at this in person, the general consensus was
We were dealing with a discrepancy of <.18"
Shaved the spindle by .18" which has no ill side effects because there was almost .53" of exposed spindle after the bearing retaining nuts were installed.
Anyway, it's all fixed, and I still don't understand why that happened. All bearings and races were the exact same part numbers that were in it before, the only difference is being the 35 spline lockout which has the same depth as a stock lockout.
Old January 6th, 2010, 06:26 AM   #74
boggin-machine
boggin-machine's Avatar
glad to hear you got it all figured out. who was the master that figured it out?
i dont understand what the hell could of made the difference?
Old January 6th, 2010, 07:01 AM   #75
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Wow. that's the biggest difference that .18 has ever made on something that takes that kind of abuse.... lol!!!!
Old January 6th, 2010, 07:07 AM   #76
kixx007
Certified Ypsilantian
kixx007's Avatar
Is this thing done yet?
kixx007 is offline   Reply With Quote
Old January 6th, 2010, 07:32 AM   #77
You didn't shave the spindle, you shaved the stub axle shaft.
Old January 6th, 2010, 07:34 AM   #78
clarkstoncracker
lol
You were probably sound asleep when the spindles were being shortened.
Old January 6th, 2010, 07:56 AM   #79
kixx007
kixx007's Avatar
Yeah, we just started shaving everything, it was good times. If it got near the cut off wheel, it got shortened.
Old January 6th, 2010, 08:37 AM   #80
Shortening the spindle would do no good. If anything, it needed to be extended. You're right, I was sleeping while you were hacking.
By the way, you were off fucking off while I was wasting my evening looking at your problem.
Page generated in 0.38494 seconds with 83 queries
