Dana 60 lockout hitting the spindle. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 12:51 PM   #41
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Same part numbers for Ford and Chevy locking hubs. I've lent my spare ford locking hubs to my friend that runs a Chevy, so I know they interchange.
That's what makes me wonder about the hub itself. It can't be the spindle since they have different patterns.
As geoboy has asked, do the brakes fit right?
JohnnyJ is online now   Reply With Quote
Old January 5th, 2010, 12:54 PM   #42
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
i assume yes after bullshitting with him in chat. ive went through the bible myself didnt see anything
Old January 5th, 2010, 12:58 PM   #43
clarkstoncracker
lol
clarkstoncracker's Avatar
I really don't have any more answers, as brakes were never put on. I'm going to remeasure hubs and spindles in a bit and find out what they actually are. I would be extremely surprised to find if either the spindle or the hub is not factory for that axle.
Old January 5th, 2010, 01:03 PM   #44
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Yeah- it looks like Warn only makes 1 part number for the 35 spline stubs.
back to the stubs again.....
According to Mr. N's these are the total lengths:
Ford:11 13/64"
Chevy: 12"
Dodge: 11 1/32"
I hope these measurements help!!!!
Old January 5th, 2010, 01:04 PM   #45
clarkstoncracker
lol
thanks a ton sandvipr.
Old January 5th, 2010, 01:07 PM   #46
joe_jeep
welfare wheeler
joe_jeep's Avatar
the chevy stubs and ford stubs put the groove for the lock ring in a different location by about 3/8's of an inch. chevy stubs should be 12inches. i thought there was 2 different ford stubs. one for kingpin, and one ball joint.
my kingpin ford stubs measure from the center of the u-joint hole to the snap ring groove at about 11 and 1/8th (measured with a crappy tape measure). 8.5 from the tip of the splines to back side of the yoke. about 12.5 overall from end to end(outside to outside).
it kinda sounds like you got chevy stubs. jmho
good luck
Old January 5th, 2010, 01:14 PM   #47
95geo
newbie
95geo's Avatar
Why are we back on the topic of stub shafts? I thought this was a spindle/wheel hub/lockout stack up issue?
Old January 5th, 2010, 01:16 PM   #48
95geo
newbie
95geo's Avatar
And unless I missed it, you never said if you got the axle completely assembled or in boxes?
Old January 5th, 2010, 01:18 PM   #49
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
To dovetail in with Geo- do both sides hit or just 1? (or still in assembly mode?)
Old January 5th, 2010, 01:18 PM   #50
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I think this was on page 1:
Maybe, but I would find that really surprising since this axle came out of a driving 1979 f-250.
I guess you'll have to measure the hubs when you get back and see if they're chevy or ford.
Old January 5th, 2010, 01:24 PM   #51
joe_jeep
welfare wheeler
joe_jeep's Avatar
i was just trying to rule out having the wrong stub.
i took the measurements cause my stubs were right next to me.
Old January 5th, 2010, 01:29 PM   #52
95geo
newbie
95geo's Avatar
Makes sense.
Are the wheel bearings the correct part numbers with the right thicknesses? I'm just thinking about off the wall crap at this point....
Old January 5th, 2010, 01:34 PM   #53
clarkstoncracker
lol
Makes sense.
When I get back to the axle, I'm going to measure the spindles first. If they're actually ford spindles, then I'm going to take out the bearings, go to napa and measure them to the proper bearings.
I have the old bearings I pulled out of this axle, and they're the same as the bearings that I put in. The parts are very easy to assemble, hence why I'm lost as to what happened here.
Old January 5th, 2010, 01:40 PM   #54
liv2mx
i like jungle gym's.
liv2mx's Avatar
butler has one of my spare hubs. there is a complete set of good bearings in that.you can take them if you need them.
Old January 5th, 2010, 01:42 PM   #55
clarkstoncracker
lol
thanks d-bag. I need to call him anyways
Old January 5th, 2010, 01:48 PM   #56
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The spindles can't be wrong, unless you redrilled from 6 to 5-lug.
Although a bit further than the local napa, Jeff's bronco graveyard is a good source for ford d60 parts in a pinch.
http://broncograveyard.com/
Old January 5th, 2010, 01:51 PM   #57
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
X2 it has to be a bearing or a race in the wheel hub
Old January 5th, 2010, 01:53 PM   #58
Stupid Question, but if you installed new races with the bearings, did the races get seated fully? If the inner race isn't fully pressed into the hub it could throw everything else out.
Old January 5th, 2010, 01:58 PM   #59
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
good point....
NitzPixs is offline   Reply With Quote
Old January 5th, 2010, 02:11 PM   #60
kj kyle
kj kyle's Avatar
the way i see it... the only part that can change the relationship between the lockout and spindle, would be hubs (or bearings)....
I would check to make sure the bearings, and races are seated, and if so run the part numbers and make sure you have the right ones.
are the hubs aftermarket?
kj kyle is offline   Reply With Quote
Page generated in 0.58562 seconds with 83 queries
