Dana 60 lockout hitting the spindle. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 11:24 AM   #21
What brand 35 spline stubs are you using?
Old January 5th, 2010, 11:26 AM   #22
95geo
newbie
95geo's Avatar
You say that stock spacers are larger? Is that what I'm missing, should I have spacers in between the spindle and inner bearing on the hub?
Stock caliper brackets are 1/2" thick.... or 3/8" brake plate plus a 1/8" spacer for the adjustment/offset.
But would spindle depth change the hub to spindle relation? sounds like that still wouldnt be the problem, even if it werent right.
Old January 5th, 2010, 11:26 AM   #23
clarkstoncracker
lol
clarkstoncracker's Avatar
that has nothing to do with my problem. Even if my axle shafts were 40' long and splined, I couldn't get my lockout in because it hits the spindle.
Old January 5th, 2010, 11:27 AM   #24
clarkstoncracker
lol
Yes, if I make the bearing mating surface of the spindle 3/8" out further, it should in theory make the spindle recess the same distance into the hub.
Old January 5th, 2010, 11:28 AM   #25
I was just curious...
Old January 5th, 2010, 11:30 AM   #26
95geo
newbie
95geo's Avatar
But then your brake caliper to rotor would be off 3/8". Does it line up right now?
Old January 5th, 2010, 11:32 AM   #27
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Sorry, I was correcting Skooter_built that the stock caliper brackets are thicker than 1/4".
In my 78-79 ford 60, there aren't any spacers on the spindle. Only thing that is technically a spacer is the caliper bracket that is between the knuckle and spindle.
If it came out of a driving vehicle, then I doubt they are mis-matched but might be worth checking since 3/8" is real close to the diff between the chevy and ford versions. I wasn't sure if you got it as a pile of parts or complete axle.
Have you tried rebuilding with stock outers and hubs? Does it work? If you don't have any, I have a spare set that you could use for mockup.
JohnnyJ is online now   Reply With Quote
Old January 5th, 2010, 01:06 PM   #28
liv2mx
i like jungle gym's.
liv2mx's Avatar
you have something in backwards.
if it is hitting the spindle your bearings are too small,means your caliper is going back too far.
your caliper bracket is on wrong.
you said you tried a stock lockout so it is not the lockout...
check were the caliper bracket goes into the spindle and make sure there is no bur there not letting the two seat together properly.
that is all that i can think wrong..is both sides doing this or just one?
Old January 5th, 2010, 01:07 PM   #29
liv2mx
liv2mx's Avatar
there is the old heat shields that act like a spacer in there...
Old January 5th, 2010, 01:11 PM   #30
Bones
Bones's Avatar
take it to JCR?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 5th, 2010, 01:11 PM   #31
clarkstoncracker
lol
Does the heat shield go in between the brake bracket and the spindle?
Old January 5th, 2010, 01:13 PM   #32
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
I do not have a heat shield on my and everything clears fine.
NitzPixs is offline   Reply With Quote
Old January 5th, 2010, 01:16 PM   #33
liv2mx
liv2mx's Avatar
yes. i dont have them on mine but they could make a diffrence if you have custom shafts.
Old January 5th, 2010, 01:16 PM   #34
Pokerob
hug life
Pokerob's Avatar
x2 fukc a heat shield.
Old January 5th, 2010, 01:18 PM   #35
liv2mx
liv2mx's Avatar
you could make a spacer and put it there to get the clearance you need. drill the 8 hols and make it out of some tin or anything you have laying around that would act as a spacer.
Old January 5th, 2010, 01:18 PM   #36
clarkstoncracker
lol
I'll see you tonight.
Old January 5th, 2010, 01:18 PM   #37
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Sorry- but I've never had that 18 gauge heat shield even make any difference. I always take that rotted-out mud catcher out and have never had 1 bit of an issue.
2 more thoughts... Wrong application lock-outs or maybe your hubs were switched out with chevy or dodge ones with a different offset????
I'd also check the D 60 bible on Pirate and get some dimentions/POI's on the componants that you are using. Something is off a little weather it was your fault or the last guys- (and I'm betting that someone did a brake change without letting you know about it.....)
Old January 5th, 2010, 01:24 PM   #38
liv2mx
liv2mx's Avatar
the issue is you need to get this together for the weekend..make it work then figure it out when you get home.
Old January 5th, 2010, 01:28 PM   #39
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
He's going to need a 3/8" spacer though... hmmmm.... Let me hit the bible a minute myself and see if anything looks framilliar....
Old January 5th, 2010, 01:38 PM   #40
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
OK- There's 5/8" difference in the length of the chevy vs. ford outer stubs and hub assemblies.
I would dare say that you have the longer Chevy stubs on there. Nothing else makes any sense except maybe wrong lock-outs. I'll keep checking to see if there's anything else that sticks out......
Page generated in 0.53527 seconds with 83 queries
