Dana 60 lockout hitting the spindle. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2010, 07:04 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Dana 60 lockout hitting the spindle.
The hub seats properly.
Lockout hits the spindle before going completely in. I thought it was just an extra depth of a 35 spline lockout, but found some stock lockouts and it's the same.
What am I missing here? It seems that the hub and the spindle is a set depth once it's locked together. Lockouts were on this hub/spindle combo before.
I have room to shave off 1/2" on the spindle with room to spare for the bearing lock nuts, but that doesn't seem like the proper fix.
Old January 5th, 2010, 07:08 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
never mind I read it wrong
Yetti
Old January 5th, 2010, 07:16 AM   #3
Yetti
Yetti's Avatar
Yetti
Old January 5th, 2010, 07:26 AM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Hmmm. C-clip missing? or maybe the incorrect bearing installed on the back side of the hub?
Just a couple thoughts.....
Old January 5th, 2010, 07:28 AM   #5
clarkstoncracker
lol
I can get the inner c-clip on, but I can't get the outer on, because the lockout needs to slide back another 1/4".
Having a bigger bearing on there would help my problem by moving the hub further out I have the right bearings in there though.
Old January 5th, 2010, 07:45 AM   #6
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Shouldn't it hit the stub before it hits the spindle???
To me it sounds like your stub is too long
Old January 5th, 2010, 07:51 AM   #7
atvextreme
atvextreme's Avatar
i know its not the same axle, but i had the same problem on my 44 when i rebuilt it. (from what i can tell of your description)
the stub shaft would seat itself so far back as i re-assembled the knuckle, that you couldn't just pull it forward to get the last c-clip back on.
The spindle seal would "roll-over" and cause the stub shaft to be recessed to far.
I had to tear it back down and re-seat the outer shaft back into the spindle seal. while holding the stub shaft from being pushed back inward , toward the diff.
or the stone shield as in yetti's post.
atvextreme is offline   Reply With Quote
Old January 5th, 2010, 08:04 AM   #8
95geo
newbie
95geo's Avatar
Check to make sure the stubs are the same length between chevy and ford, I cant remember if they are off the top of my head but if they are the same then you just need to get a screw driver or pry bar and push/pry the whole shaft deeper into the housing using the ears on the shaft and the back side of the knuckle. If it's bottoming out in the differential and not allowing it to go any further then you'll need to cut the inner down some.
Old January 5th, 2010, 08:08 AM   #9
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Chevy 12" stub ford 11.4" stub.
Old January 5th, 2010, 09:27 AM   #10
clarkstoncracker
lol
That isn't the problem. The shafts are the proper length. I can put the lockout in, and put the snap ring on the axle shaft without issue. The problem comes is the lockout is physically making contact with the spindle, not allowing the installation of the outer snap ring, and the lockout cover will not sit into the hub over the inner part of the lockout because the inner is making contact with the spindle.
But my question is, why? The only parts of this complete axle that I kept from the old setup is the spindle, hub, and brake bracket.
Old January 5th, 2010, 09:40 AM   #11
Renegade II
Coil springs are for pens
Renegade II's Avatar
Is it hitting by roughly the width of the caliper bracket? Did you put the spindle under or over the caliper bracket?
Old January 5th, 2010, 09:55 AM   #12
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
OHHHHH Id say is was that!!! Ive done that before That bracket should be about 1/4" thick too.
I'm the man in White.
Old January 5th, 2010, 10:01 AM   #13
clarkstoncracker
lol
I put them on
Knuckle - Caliper bracket - Spindle
Should it be
Knuckle - Spindle - Caliper bracket?
if its the 2nd, then that was obviously the mistake, and that would sink the spindle in the distance I need
Old January 5th, 2010, 10:03 AM   #14
Jeepaholic
Jeepaholic's Avatar
nope that is right for a ford.
I say drive slugs and be done
Old January 5th, 2010, 10:05 AM   #15
Skooter_Built
I put them on
Should it be
Did you bolt on the caliper onto the bracket yet? If thats 1/4" off like the lockout, then you have the order of parts off.
Old January 5th, 2010, 10:13 AM   #16
95geo
newbie
95geo's Avatar
Ford
Chevy/Dodge
Not sure about the hubs hitting the spindle, are your spindles 5 bolt fords? What lockouts are you using?
Old January 5th, 2010, 10:16 AM   #17
clarkstoncracker
lol
Originally Posted by 95geo View Post
Ford
Chevy/Dodge
Yes, 5 bolts, and they were on the axle to begin with which appeared stock. I'm using warn premium 35 spline lockouts. The 35 spline lockout case looks identical to the 30 spline stock case in depth.
wonder if I can put a spacer between the inner bearing on the hub and the end of the spindle, just to bump it out 3/8" of an inch or so.
Old January 5th, 2010, 10:20 AM   #18
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Could it be that you have chevy hubs?
Knuckle - Caliper bracket - Spindle is correct for ford parts. And the brake brackets are thicker than 1/4" (you can get by with 3/8" spacer, but I think they are bit thicker from the factory.)
Old January 5th, 2010, 10:22 AM   #19
clarkstoncracker
lol
Maybe, but I would find that really surprising since this axle came out of a driving 1979 f-250.
I guess I'll have to measure the hubs when I get back and see if they're chevy or ford.
You say that stock spacers are larger? Is that what I'm missing, should I have spacers in between the spindle and inner bearing on the hub?
Old January 5th, 2010, 10:24 AM   #20
95geo
newbie
95geo's Avatar
Are they the same part number for a ford and chevy? I'd assume so but something doesnt seem right....
As long as you were still on the bearing surface on the spindle I dont see any reason why it wouldnt work temporarily as long as everything lines up.
Did you put the brake rotor on the back side of the wheel hubs?
And just because it sounds like something really "dumb".... You made sure the proper races were in the wheel hubs, right? It sounds like the hub is sitting too deep on the spindle, for some reason.
Page generated in 0.52822 seconds with 83 queries
