What would I need to re-gear? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2010, 09:34 PM   #1
awalters
Hired Badass
awalters's Avatar
Default What would I need to re-gear?
I read the sticky, and didn't quite understand it. I have a stock Dana 30-35 setup, and I just blew the transfer case, and broke something in the front end. I figured, while we're in there, to re-gear these.
I want to put 4.88's, or maybe 4.56's in it. Would I need a new carrier to do either of these?
Also, what is stock gear ratio, in the D30 and D35 for Wranglers? It's a TJ if that matters.
awalters is offline   Reply With Quote
Old January 4th, 2010, 09:36 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Engine and trim level will make a difference. Could be 3.08, 3.73, or even 4.10.
Old January 4th, 2010, 09:46 PM   #3
awalters
Hired Badass
awalters's Avatar
It's a 2.5L 4 cylinder. 1997.
Old January 5th, 2010, 12:54 AM   #4
xjmichigan
xjmichigan's Avatar
From the sounds of it you already have 4:10s f/r so your carrier could be reused. You would just need a set of ring and pinions and a install kit.
Page generated in 0.15395 seconds with 35 queries
