Intake Manifold Gasket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2010, 06:56 PM   #1
tony_gapczynski
tony_gapczynski's Avatar
Default Intake Manifold Gasket
im planning on replacing my intake manifold gasket on my 5.2 this weekend. first time doing it, anyone have any tips or good pointers?? thanks!
tony_gapczynski is offline   Reply With Quote
Old January 5th, 2010, 10:38 PM   #2
koochman450r
koochman450r's Avatar
if its a stock cast iron manifold get a buddy to help you lower it into place cuz they're one heavy sombitch. Nothing too difficult you should be able to keep the throttle body attached to the manifold so you dont have to replace that gasket, just unhook your fuel lines. distibutor doesnt have to come out so thats a plus. just take your time and clean everything really good so you dont have to redo it in a month. Good luck
Old January 13th, 2010, 10:08 PM   #3
Junkyard
Junkyard's Avatar
I just had to do one if you want to keep it from leaking get a felpro kit and a mopar kit use the mopar end seals and the steel gasket for the plate on the bottom of the intake and use the felpro side gaskets. Seems like a waste of cash but the felpro kit comes with cork end seals that leak like a bitch the mopar kit is rubber. and for some reason the mopar side gaskets leak after 200miles. Its not really a fun job to do so its a good way to make sure you only have to do it once. Also get new bolts for the base plate on the intake if you dont replace them the rattle out and fall in the motor.
Junkyard is offline   Reply With Quote
Page generated in 0.26045 seconds with 32 queries
