I want a 351w - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2010, 02:00 PM   #1
MARTIN HASSENGER
BRONCATRON
MARTIN HASSENGER's Avatar
Default I want a 351w
I am looking for a 351w out of any thing, running would be my first choice, but i can work around it if the price is right. I can pick it up just about any where in the state. let me know what you got. also id like it to have a carb but as I said I can work around stuff like that.
MARTIN HASSENGER is offline   Reply With Quote
Old January 4th, 2010, 02:02 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Can sell you a long block from a 95 with accesories for $325, uses the same style roller cam as a 5.0
Old January 4th, 2010, 02:46 PM   #3
MARTIN HASSENGER
BRONCATRON
little much for me mostly because of the fuel injection thanks any way
Old January 4th, 2010, 02:58 PM   #4
Jeepaholic
Jeepaholic's Avatar
maybe you should post a price range then?
Old January 4th, 2010, 03:14 PM   #5
MARTIN HASSENGER
BRONCATRON
I would put a price range but I never know what might catch my eye so i want to see what everyones got your price turned me away because of the fuel injection and the year. I dont want to spend a whole lot if i dont have to. I just want to see whats out there. Thank you for the advice thou.
Old January 4th, 2010, 03:20 PM   #6
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
So your expecting a running engine for less then $300 ?
$250 is generally a CORE price FWIW. Just trying to help you out. If you find a running engine that doesn't have 80/90W hiding some rattles I would be quite surprised.
You could probably adapt that FI motor to take a carb pretty cheaply. It would be dumb (IMO) but it MAY be possible, I know you can on a Chevy.
Old January 4th, 2010, 03:45 PM   #7
laser92
I've got a workable block crank and heads. Pistons and rods too, but one skirt broke when we moved a few years back.. $50 I'd have to double check, but IIRC it's a carb block. LMK via PM if your interested
laser92 is offline   Reply With Quote
Old January 4th, 2010, 04:57 PM   #8
MARTIN HASSENGER
BRONCATRON
I never said that it had to be running and im shure that i couldent find one that is in great working order for less than 300. I can work with any thing im just finding out my options, Thanks
Old January 5th, 2010, 07:20 PM   #9
KGB-ZR2
dirtball
KGB-ZR2's Avatar
Send a message via AIM to KGB-ZR2
bump for a good guy someone find this man a windsor!!!!
KGB-ZR2 is offline   Reply With Quote
Old January 5th, 2010, 07:57 PM   #10
performen460
performen460's Avatar
Default motor
i have a 351w with 50,000 miles it was in a 90 ford van that i parted out. it was a ford remanafactured engine ran great then i sold the heads off it them replace them with a set off a 69 mustang heads and a alum intake on it then ran it in my bronco for a little while then i took it out to put a built 460 in it but the 351w ran real good i wish i didn't take it because then i blew the 460 up now i building another 460 for it and don't need the 351w so the 351w comes complete from intake to oil pan, fly wheel, dist, water pump, valve covers, shorty headers, have a carb but will need to be rebuilt all for the price of $450.00 let me know
thanks dan
performen460 is offline   Reply With Quote
Page generated in 0.35470 seconds with 53 queries
