fullsize or not. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2010, 01:48 PM   #1
caveman
GeoDude
caveman's Avatar
Default fullsize or not.
i've got a 93 yj with fullsize chevy axles under t right now and just got back from rocks and valleys in a tj and had a blast. my worry is that my buddy with the tj had some tight squeezes and if i was in my yj, i'm sure we would have missed a trail or two. i'm wanting to run between a 35 and 38. what are good axle options for me. i was thinkin wide track cj axles or wagoneer axles maybe. and when i'm askin for advice i want something pass drop. leaf sprung, and come factory with 4:10s
Old January 4th, 2010, 01:52 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Are you going to lock the front end?
Old January 4th, 2010, 02:36 PM   #3
caveman
GeoDude
caveman's Avatar
one day. i'll start in the rear.
Old January 4th, 2010, 02:39 PM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Locked front and ANYTHING over a 35 or 36, just do yourself a favor and go with a 60 right off the bat. You could always narrow it to suit your tastes. As a matter of fact, I just saw one of those on here. It needed to be finished, but it was a great buy for the $$$.
Old January 4th, 2010, 03:25 PM   #5
caveman
GeoDude
caveman's Avatar
well i'm not willing to spend money on a 60 let alone a 60 and narrowing it. i'm looking more a less d44 options.
Old January 4th, 2010, 04:18 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
waggy axles are pretty narrow. could live with 35's or 36's if built right and wheeled smartly. if you hammer down all the time dont go with less than a 60
Old January 4th, 2010, 05:01 PM   #7
caveman
GeoDude
caveman's Avatar
how much wider is a waggy than say a cj axle?
Old January 4th, 2010, 05:19 PM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
cj axle will be narrower than the stock yj axles. A narrow track waggy axle is real close to the same width as a stock yj or tj axle. I don't think you could get 4:10's in one though.
Rear axle to match the front you can get a waggy 44, isuzu 44 rear will have disc's and available with 4:10's or 4:30's. Could also run a Early Bronco 9" rear or a Scout 44 rear with a hub swap on the front to 5 lug
Easiest thing to do would be to run wheels with higher backspacing on the chevy axles which will bring the tires back in for a narrower overall width
Page generated in 0.35689 seconds with 47 queries
