misalignment spacers, 5/8". I need two sets - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2010, 12:53 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default misalignment spacers, 5/8". I need two sets
Anybody have them laying around, or know where I can find them in SE Michigan?
I've tried Jeeperzcreepers, mumbleys, and unlimited.
clarkstoncracker is offline
Old January 4th, 2010, 12:56 PM   #2
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
ebay
MJ_Silver_1988 is offline
Old January 4th, 2010, 12:56 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I got so much stuff here what are you trying to aline?
that and give me a description of what you want the spacer to look like?
Yetti
Yetti is offline
Old January 4th, 2010, 01:01 PM   #4
clarkstoncracker
lol
http://www.jeeperz-creeperz.com/wide...s-p-41163.html
Old January 4th, 2010, 01:03 PM   #5
Yetti
Yetti's Avatar
Ok thats not what I have. I don't think I can help , sorry
Yetti
Yetti is offline
Old January 4th, 2010, 01:06 PM   #6
chevotass
chevotass's Avatar
go to home depot. spend $8 on a piece of 3/4" tubing. inside diameter will be 5/8" cut pieces to desired width. install. if you want to get fancy after you install them tack weld them to the brackets so if you ever have to pull a link out to work on something they wont fall out.
chevotass is offline
Old January 4th, 2010, 01:07 PM   #7
clarkstoncracker
lol
thanks, I went to two hardware stores looking for it, didn't know the depot carried it
Old January 4th, 2010, 01:15 PM   #8
Bones
Bones's Avatar
Buy the AL tube, not steel (IMO)
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Bones is online now
Old January 4th, 2010, 01:24 PM   #9
Yetti
Yetti's Avatar
I think I found an alternative. since its just a spacer to increase angle you can use a lug nut drilled to the correct bolt size or you can use a stub shaft nut? I went to the barn and I have crap loads of them. the center is 23/32" which is slightly larger then you need, but if you go to some place like auto zone you might fine one closer to the 16mm or 5/8" . even if you had to run a drill through it its a hardened nut that wouldn't collapse like mild steel would
Yetti
Yetti is offline
Old January 4th, 2010, 01:26 PM   #10
clarkstoncracker
lol
I guess I could use hockey pucks to lift the body too
Old January 4th, 2010, 01:28 PM   #11
Pokerob
hug life
Pokerob's Avatar
[quote=clarkstoncracker;2020600]
I think I found an alternative. since its just a spacer to increase angle you can use a lug nut drilled to the correct bolt size /QUOTE]
Do you get banned when you mess up quoting? I am just curious.
gl finding your spacers
Pokerob is offline
Old January 4th, 2010, 01:31 PM   #12
Yetti
Yetti's Avatar
I just posted the pic above of the nuts I found, they are shouldered just like the store bought spacers, say what you will, but if it works till you get the correct ones then don't knock it
Yetti
Yetti is offline
Old January 4th, 2010, 02:19 PM   #13
clarkstoncracker
lol
Ridin Dirty made me some billet aluminum ones, he even carved my initials into them
Old January 4th, 2010, 02:44 PM   #14
95geo
newbie
95geo's Avatar
What grade aluminum? I wouldnt run aluminum misalignment spacers on single shear steering unless they were 7075 or better, even then, a double shear tab or flange would be a good idea also.
$0.02
95geo is offline
Old January 4th, 2010, 02:46 PM   #15
clarkstoncracker
lol
$0.02
wrought magnesium alloy
Old January 4th, 2010, 02:49 PM   #16
Mclovin
"The Situation"
Mclovin's Avatar
ive got the misalignment spacers that came with my 3/4 ruffstuff heims.. I think the ID is 5/8ths ?
Mclovin is offline
Old January 4th, 2010, 02:56 PM   #17
95geo
newbie
95geo's Avatar
Sounds like it'll last a lifetime, or two.... Keep an eye on the bolts, they loosen up a lot at first, especially with paint on the surfaces.
95geo is offline
Old January 4th, 2010, 02:57 PM   #18
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Ridin Dirty is offline
Page generated in 0.40743 seconds with 77 queries
