99 gmc jimmy 2dr 4x4 *sold* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2010, 07:56 PM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default 99 gmc jimmy 2dr 4x4 *sold*
99 gmc jimmy 4x4 4.3 auto **FEELER**
~139k mile's but it is my dd so they will continue to go up
31-10.50-15 mastercraft courser mt's 5 of them 4 mounted on the truck and a 5th with matching wheel to the rest for full size spare
~1-1.5" of t.b crank to help clear the 31's
summit racing cap and rotor along with summit 8mm wire's and ac delco rapid fire plug's done 12-30
k&n drop in filter
6" hella's in the grill on a toggle wire'd through a relay
both wheel bering's with skf's ~15-20k mile's ago
also have new in box 2 1/4" summit 12" glasspack and transgo hd2 shift kit
i more want to trade it for a 95+ ext cab 4x4 chevy because i need a truck to haul wood with or 4250 obo
will get pic's eventually my comp isn't coperating(sp) right now
ID:	55092   Click image for larger version
ID:	55093   Click image for larger version
ID:	55094   Click image for larger version
ID:	56988   Click image for larger version
beaterk5 is offline
Old January 3rd, 2010, 06:58 AM   #2
beaterk5
beaterk5's Avatar
bump for getting pic's up
beaterk5 is offline
Old February 4th, 2010, 11:42 AM   #3
beaterk5
beaterk5's Avatar
still have it, thought id try again also almost 141k miles now and could probly use balljoint's this spring
beaterk5 is offline
Old February 4th, 2010, 06:23 PM   #4
plowboy
4Wheel 4 Life
plowboy's Avatar
I have a 1994 chevy ext cab sb 4x4, for trade. Its black with red interior, no rust, no dents, rebuilt trans, new bearings and seals in transfercase, new 265/75-16 toyo tires, flowmaster exhaust, cold air intake, trailer hitch, tune up, fuel pump and filter, and steering rebuilt. 130,000 miles. 350 motor. If interested?
plowboy is offline
Old February 5th, 2010, 10:40 AM   #5
beaterk5
beaterk5's Avatar
pmed you
beaterk5 is offline
Old February 16th, 2010, 05:17 PM   #6
beaterk5
beaterk5's Avatar
one last bump will conside all reasonable cash offer's and also consider auto tran's 73-87 truck's 2 or 4wd
beaterk5 is offline
Old April 12th, 2010, 05:44 PM   #7
beaterk5
beaterk5's Avatar
bump, rearend messed up i belive the cross pin fell out and smacked the pinion and the shock load killed 4th and 1st so i belive the roller clutch or sprag i forget which dose what, but still has manual 1st
i would like about 1900 but make an offer prefer no trade's but shoot the worst i can say is no
may also trade this plus my stepside together for a decent ext cab gm or 73-87 truck or 73-91 suv
beaterk5 is offline
Old April 20th, 2010, 03:25 PM   #8
beaterk5
beaterk5's Avatar
make a reasonable offer
beaterk5 is offline
Old May 23rd, 2010, 09:38 AM   #9
beaterk5
beaterk5's Avatar
1200 obo 1000 obo without the 31's on box style s10 rim's with like new 235's
and a pinion bearring race shattered and the ring an pinion caught it is what appear's to have happened to the rear axle
beaterk5 is offline
Old June 15th, 2010, 10:17 AM   #10
beaterk5
beaterk5's Avatar
sold
beaterk5 is offline
Page generated in 0.26689 seconds with 54 queries
