how do i find out what gears are in my d30??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2010, 11:38 AM   #1
johnny64
johnny64's Avatar
Default how do i find out what gears are in my d30???
i need to know how i go about finding out what gears i have bc they are not stock 3.55's.....if someone knows please let me know how to so i can find out thanks....
johnny64 is offline   Reply With Quote
Old January 2nd, 2010, 11:47 AM   #2
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
Pull the front diff cover off (like doing a fluid change). There will be a set of numbers stamped on the side of the ring gear. (eg. 9 - 37, Divide 37 into 9 and you get a 4.11 gear ratio). Make sure to use gasket sealer to seal back up the diff cover and put fluid back in it, 80-90w and fill it till it starts coming out the fill plug in the cover.
NitzPixs is offline   Reply With Quote
Old January 2nd, 2010, 11:50 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
jack up the axle.
rotate the tires.
Count how many times you rotate the tire for a complete revolution of the driveshaft.
that is your gear ratio
Old January 2nd, 2010, 11:58 AM   #4
johnny64
johnny64's Avatar
my tires spun 1x to my drive shaft 4.5x
Old January 2nd, 2010, 11:38 PM   #5
PavementPounder
PavementPounder's Avatar
Sounds like 4.56. If the axle wasn't regeared by a PO, IIRC that ratio was only available in a 4-cylinder with the tow package in an XJ (basically means the vehicle would have to have been specifically ordered that way). There's no tag on the diff cover? it would have been between two bolts on either vertical side.
If there's no tag, or the ratio on the tag does not reflect 4.56, you need to do this in order to 100% confirm what you have:
Old January 2nd, 2010, 11:39 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
then its 4.56
Old January 3rd, 2010, 01:10 PM   #7
johnny64
johnny64's Avatar
ok thanks
Page generated in 0.24677 seconds with 44 queries
