Lube required for carrier bearings? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2009, 09:31 PM   #1
Camo-5
And yet another Heap.....
Camo-5's Avatar
Default Lube required for carrier bearings?
I just removed the carrier from my Dana 44 to clean up the housing and install my custom Lincoln Locker and I'm wondering if I need to pack the carrier bearings with grease before I reinstall everyting or if they are lubricated via the case gear lube (which I suspect). I figured I'd ask before I get everything back together and find out otherwise.
Thanks.
Camo-5 is offline   Reply With Quote
Old December 31st, 2009, 10:40 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Myself I use regular wheel bearing grease. that way it has enough till it gets the gear lube thrown around and mixed in. I found it helps on pre-loading the pinion bearings. nothing like a dry bearing to ruin your day
Yetti
Old December 31st, 2009, 11:15 PM   #3
94jimmyjr
94jimmyjr's Avatar
word
94jimmyjr is offline   Reply With Quote
Page generated in 0.18206 seconds with 32 queries
