Lets see pics of jeeps with body lifts and suspention lifts together - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old December 30th, 2009, 10:53 PM   #1
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Send a message via Yahoo to lizzardboy
Default Lets see pics of jeeps with body lifts and suspention lifts together
With a picture of your jeep please describe how much body lift and suspention lift you have including shackles if you have them. Also iunclude size tire your running.
lizzardboy is offline   Reply With Quote
Old December 30th, 2009, 10:56 PM   #2
boggin-machine
boggin-machine's Avatar
you wont find many people on here with over a 1 inch body lift on jeep here.
Old December 30th, 2009, 10:57 PM   #3
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Im trying to get an idea of what to do with mine. It has 3" BL and 3" suspention. I dont really like that big of a BL but do like the height of the jeep. Im running 33x13.5 TSL's. Adding shackles and taking out the BL I think it will look better. Any ideas anyone?
Old December 30th, 2009, 10:58 PM   #4
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Send a message via AIM to Xj Wheeler
my xj has a 4 inch body lift..
Xj Wheeler is offline   Reply With Quote
Old December 30th, 2009, 10:58 PM   #5
96 s10 blazer
96 s10 blazer's Avatar
1" body lift and 6" suspension and run some35's on your jeep
96 s10 blazer is offline   Reply With Quote
Old December 30th, 2009, 11:00 PM   #6
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
nice looking yj btw looks like the top could use replacing though.
Old December 30th, 2009, 11:05 PM   #7
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Well I dont want to get new springs, I bought the jeep like this . I was thinking of taking the BL down to 1" and adding 2" shackle to the already 3" springs and that should give me the hieght back with a better look. Think that will look ok?
Old December 30th, 2009, 11:06 PM   #8
lizzardboy
Jeepcrazy
lizzardboy's Avatar
Yes very much so, That is the first thing I will get for it.
Old December 30th, 2009, 11:12 PM   #9
Soy_bomb
Web Wheeling!
Soy_bomb's Avatar
That would be the best solution for the best price.
Soy_bomb is offline   Reply With Quote
Old December 30th, 2009, 11:29 PM   #10
kl01
kl01's Avatar
the info 4 inch lift springs i think 1"in Currie lift schackels 34-10.5-16 on dodge rims 2 inch wheel spacers to clear driver side tie rod end super swampers 2 no bodie lift it fubar's evry thing
kl01 is offline   Reply With Quote
Old December 31st, 2009, 12:23 AM   #11
mrclean
Silver Lake
mrclean's Avatar
89 YJ with a 2" body lift (came that way, I didn't put it on) and 4" Rough Country spring. Drive train is a 2.5, 5-speed, 231 at the moment. I currently have 35's on it at the moment.
ID:	55004   Click image for larger version
mrclean is offline   Reply With Quote
Old December 31st, 2009, 01:34 AM   #12
wayne94gt
Default lift
flipping the axles to the bottom side of the spring should gain about 3-4 in of lift. if you have a welder it should be cheep also. you can then pitch the bl or go down to 1in. that long of shackles would worry me. the only thing with the under spring setup is you are more likly to have a wheel hop issue
wayne94gt is offline   Reply With Quote
Old December 31st, 2009, 01:41 AM   #13
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
95 YJ, SOA front (5.5") Coil rear (6") and a 1" body lift on 35's
TJ flares help quite a bit.
Jesse-James is offline   Reply With Quote
Old December 31st, 2009, 06:15 AM   #14
Actually you'll get more than 5" by doing a SOA and if you do it right, it's not all that cheap. You don't want to just flip your existing springs, you need to change them. Plus, shocks change, driveshafts change, steering changes.
Not really a good pic but the only one handy. Rubicon express SOA axles + 2" body lift & 35" tires.
It's not really about the body lift, it's about the overall package. Here it is linked sitting on 40's. Still has the 2" body lift. Personally, I like the body lift as it allows keeping the frame/drivetrain lower but allows less trimming, access between the frame and body, etc. It's great to be able to put a power washer between the frame and body to do a good cleanup. Also surprising how often it's good for wrench access.
Old December 31st, 2009, 07:17 AM   #15
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I agree! trim the body to 2" and trim the fenders. You can fit 35 on a stock jeep if you just trim the fenders. I have a 98 tj with 1" body and 4" suspension with 39's. Rememer that lower is better for offroad.
cvwindows is offline   Reply With Quote
Old January 1st, 2010, 07:45 PM   #16
cruiserjg
dodge man
cruiserjg's Avatar
Its only lifted on three corners now
cruiserjg is offline   Reply With Quote
Old January 1st, 2010, 08:04 PM   #17
electroman4
electroman4's Avatar
Not too mention long shackles screw up caster and then you wander like hell.
electroman4 is offline   Reply With Quote
Old January 1st, 2010, 08:04 PM   #18
billycole
Here is my wife's jeep. 4" no BL. 33x12.5 10 wide rims. Hope the link works
billycole is offline   Reply With Quote
Old January 1st, 2010, 08:08 PM   #19
dbikers
dbikers's Avatar
1" bL, 3.5" susp, 33x12.50 mt's on 8" rims, all installed approx 3 yrs ago (and is probaby saggin' a bit by now)
dbikers is offline   Reply With Quote
Old January 1st, 2010, 08:18 PM   #20
lizzardboy
Jeepcrazy
lizzardboy's Avatar
I think I will trim The 3" BL down to 1" and call it good. I like the way your guy's jeep look. I dont like my 3" BL. Makes it look like the body is floating off the frame. To much gap. Thanks for all the pics and info. It helps me on what I want to do.
Page generated in 0.49261 seconds with 83 queries
