Rear Axle - Difference between TJ and ZJ mounts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 30th, 2009, 09:07 AM   #1
srlbotanical
Because I Said So...
srlbotanical's Avatar
Default Rear Axle - Difference between TJ and ZJ mounts?
Will an axle set up for a ZJ also bolt into a TJ? I know they are both Coil sprung in the rear. Just wondering how much modification I would need to do to a ZJ axle in order to make it fit under my TJ...
srlbotanical is offline   Reply With Quote
Old December 30th, 2009, 09:13 AM   #2
kj kyle
kj kyle's Avatar
not a cherokee guy.... but i think a stock rear ZJ axle is aluminum. so it would be useless.
unless your talking about buy the 8.8 in the marketplace. then idk
kj kyle is offline   Reply With Quote
Old December 30th, 2009, 09:44 AM   #3
srlbotanical
yeah, I'm not interested in a stock ZJ axle. I've seen several axles for sale that were set up for a ZJ and I'm wondering how close they are to fitting in a TJ.
Old December 30th, 2009, 09:52 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
It'll bolt up. The Dana 44a found in some ZJ's has an aluminum center section but is still better than the D35.
Old December 30th, 2009, 09:55 AM   #5
_Kyle_
_Kyle_'s Avatar
Send a message via AIM to _Kyle_
x2. The 44a is actually a pretty decent axle - especially if you truss it. Still better than a 35 regardless though.
I wish I knew what it correlated to, by the 44a is very similar to another axle strength wise (minus the housing)...but it slips my mind currently.
_Kyle_ is offline   Reply With Quote
Page generated in 0.26755 seconds with 38 queries
