High Steer Arm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2009, 11:58 AM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default High Steer Arm
I'm gonna be buying a high steering arm soon for my Dana 60. Where have you bought them from and is anyone better than the other?? I'm a little tight on cash so i'm looking for the best bang for my buck!!
Are the ones that go over the cap better or the ones that replace the cap better??
Old December 29th, 2009, 12:15 PM   #2
boggin-machine
boggin-machine's Avatar
your talking abotu the high steer arms.
i have ran ballastic and liked them. they replace the spring so its was good for me. but at 280 a set they are kinda pricey.
sniper fab are the same idea but 269 a set.
they are all good but expensive for a 60.
Old December 29th, 2009, 12:31 PM   #3
liftedandgifted
liftedandgifted's Avatar
I also run the ballistic fab and am a fan of getting rid of the spring.
liftedandgifted is offline   Reply With Quote
Old December 29th, 2009, 03:07 PM   #4
Hoss Blazer
!SPARTY ON!
Getting rid of the spring??
Here's one from Koz Offroad and it's only $51 bucks!!
http://www.kozoffroad.com/pages_cata...ghsteering.htm
Old December 29th, 2009, 04:19 PM   #5
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Here are the ones that i bought for my D60
http://www.extremeoffroadparts.com/arms.shtml
CHEVYRCKS is offline   Reply With Quote
Old December 29th, 2009, 04:38 PM   #6
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
jcr has them too
Old December 29th, 2009, 04:44 PM   #7
boggin-machine
i couldnt remember them. i knew i was missing one. i ordered mine before they came out. i still have a flier with some of their parts and prices and they are kinda hard to beat.
Old December 29th, 2009, 04:44 PM   #8
Hoss Blazer
!SPARTY ON!
Does that repalce the cap or does it go over??
Old December 29th, 2009, 08:02 PM   #9
boggin-machine
their arms are 2 peice set. they will replace the springs as well iirc. these arms are worth the money. take the stock cap and throw them in the garbage. plus they are made localy and you can see them before you buy them.
they arent to far away in kaleva
Old December 29th, 2009, 09:21 PM   #10
Hoss Blazer
!SPARTY ON!
Which ones ya talking about??
Old December 29th, 2009, 09:29 PM   #11
boggin-machine
the extreme offroad parts
Old December 29th, 2009, 09:45 PM   #12
Hoss Blazer
!SPARTY ON!
$51 dollars to $125 though!!! Wish they had a pic of it on extreme offroad parts!
Old December 30th, 2009, 02:08 AM   #13
creeping death
I'm that guy.
creeping death's Avatar
i bought this set for mine.
http://mad4wd.com/index.php?main_pag...products_id=74
very beefy.
Old December 30th, 2009, 06:58 AM   #14
clarkstoncracker
lol
clarkstoncracker's Avatar
I just bought branik's high steer kit for the dana 60. I should have the axle assembled tomorrow and I'll take a bunch of pictures and post them in my build thread.
I was going to go with ballistic's, but they just raised pricing, and they charge for the 5th bolt and nut which seems stupid to me.
With the 10% on branik's site, the high steer ended up costing $90 less then ballistics. The down side is I'll be stuck with the two holes in the drive side, since that is all they make. Not a big deal though. The other difference in Branik's retains the spring. Not really sure the pro's or con's of each, but I believe with ballistic you have to switch out to nylon bushings.
http://www.branikmotorsports.com/dana60.htm
Old December 30th, 2009, 07:40 AM   #15
Hoss Blazer
!SPARTY ON!
What is the difference??
Old December 30th, 2009, 07:50 AM   #16
clarkstoncracker
lol
stock spring retainer with grease fitting, bolt on
branik's spring retainer, with grease fitting, welded on
ballistic's uses nylon bushings, no springs used
Old December 30th, 2009, 08:31 AM   #17
Tab
Tab's Avatar
Getting rid of the srping is supposed to keep the knuckle from "chattering" under load. As the nylon bushing and spring wear it can get worse they say. The ones that get rid of the spring use a huge allen set screw to put preload directly onto the bushing making it adjustable. It could all be a gimmick though, who knows. FWIW I have the Ballistic ones and love them, although I got them before they got real expensive.
Old December 30th, 2009, 10:42 AM   #18
Hoss Blazer
!SPARTY ON!
Thanks clarkstoncracker i understand it better now!
Old December 31st, 2009, 07:34 AM   #19
Hoss Blazer
!SPARTY ON!
Anyone else have an opinion?
Page generated in 0.32809 seconds with 80 queries
