are front and rear gears the same in an axle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2009, 05:18 PM   #1
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
Default are front and rear gears the same in an axle?
I keep hearing that the front axle gears are a tooth different from the rear. is this true? so right now I have 3.55's in my truck. my rearend went out and I have a rear axle with 3.54's. will it be ok to run the rear axle with 3.54's and the 3.55 fronts?
ATOMIC_BADBOY is offline   Reply With Quote
Old December 28th, 2009, 05:22 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
no noticeable difference. the difference between 3:54 and 3:55 usually when someone (i.e. the seller, gear manufacturer, etc.) rounds up or down. number of teeth on pinion/ number of teeth on ring gear=gear ratio.
Old December 28th, 2009, 05:29 PM   #3
XXXJ
Desert Rat
XXXJ's Avatar
All right, I heard this long ago. Maybe bullshit. When we bought a bunch of power wagon from white sands. They had 4.09/4.10. I was told they run one higher in the front to handle better in snow and sand. i.e. the front is always pulling more than the rear.
Thats what the old codger said
Old December 28th, 2009, 05:32 PM   #4
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Fords run slightly different gears front and rear from what I've seen. Fact is as long as the front and rear are within 1% of each other its ok.
BAD93SBLZR is offline   Reply With Quote
Old December 28th, 2009, 05:38 PM   #5
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Exactly what I was told too. Like you, it was an old dude who told me that.
Old December 28th, 2009, 05:45 PM   #6
ATOMIC_BADBOY
Shake n Bake
I heard the same thing to. So I should be ok to run 3.55 in the front and 3.54 in the rear, and will it be ok when I hit pavement?
Old December 28th, 2009, 05:45 PM   #7
XXXJ
Desert Rat
XXXJ's Avatar
fuckin old dudes.
They know everything.
Old December 28th, 2009, 05:46 PM   #8
Ridin Dirty
fuckin old dudes.
Yep. He said it was so the front was pulling the rear a bit.
Old December 28th, 2009, 05:47 PM   #9
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
yes
Old December 28th, 2009, 05:53 PM   #10
XXXJ
Desert Rat
XXXJ's Avatar
3.54 front/3.55 rear for it to pull. so the fronts turn more than the rear for steering.
the other way the rear will be pushing.
Old December 28th, 2009, 05:59 PM   #11
ATOMIC_BADBOY
Shake n Bake
Thats what I thought. So I guess I'm screwd. I'll have to pay the high dollar to make it right.
Old December 28th, 2009, 06:01 PM   #12
boggin-machine
boggin-machine's Avatar
you will be ok with it. nothing different from other trucks. if you spend the big bucks to make it right you will end up with the same thing.
Old December 28th, 2009, 06:03 PM   #13
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
x2 it may be that way from the factory but if you have the parts use them.
Old December 28th, 2009, 06:06 PM   #14
ATOMIC_BADBOY
Shake n Bake
Well I guess I know what I'm doing the rest of the week.
Page generated in 0.49368 seconds with 65 queries
