tube clamps - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2009, 12:57 AM   #1
Yota Bill
Default tube clamps
anyone use these type before? do they work well, or is it just complicated getting them setup? I'm sure it would be better then magnets, or a friend with a welding glove, but it seems like getting the right angle adjusted in might be a PITA...
http://www.vansantent.com/tube_positioners.htm
price is low enough, I may just buy them instead of building them
Old December 28th, 2009, 01:42 AM   #2
boggin-machine
boggin-machine's Avatar
ya we had some like that in school. they worked pretty good. the problem with them was the center section where they connect to each other wasnt the tightest. but they work a whole lot better then having a friend holding them and getting the right angle and flush contact to each other.
id spend the cash for a set for the garage if i planned on doing any amount of tube work.
Old December 28th, 2009, 06:55 AM   #3
95geo built himself a set that looked pretty good. I never heard how they panned out.
Old December 28th, 2009, 12:40 PM   #4
95geo
newbie
95geo's Avatar
They worked perfect! and the way I did the pivots it worked better than one central hinge. I used 2.0" muffler tubing for the 1.75" tube clamp and used hose clamps on either end. you could set the clamping system up a little differently but I liked how it worked with hose clamps. I could slide the tube in the clamp and it'll still hold it in place without gouging it with a bolt. They are like another 3 sets of hands that dont get shaky. You can see them in my build thread somewhere if you want some ideas.
Old December 28th, 2009, 10:06 PM   #5
Yota Bill
glad you cover your bases, I was gonna ask for pics!
Old December 28th, 2009, 11:35 PM   #6
Yota Bill
this design does look a bit easier to adjust, since it allows each tube to be adjusted seperatley from the other tube
Old December 29th, 2009, 06:17 AM   #7
jeepnxj96
jeepnxj96's Avatar
the ones that 95geo made look slick, I guess maybe I will build a set
Old December 29th, 2009, 07:22 AM   #8
rubicon
I had something like those when I was build engine mounts out of tube and they worked good. I had 12 of them and could mock up the whole mount before I started welding. The one's I had our tool maker made for me and they where a little more advance but the same concept.
rubicon is offline   Reply With Quote
Old December 29th, 2009, 11:02 AM   #9
Yota Bill
I'm thinking along the lines of making them with angle instead of half tube, so they work on a larger variety of tubing sizes...I tend to do stuff with lots of different sizes, from about 3/4 up to about 2 inch
Page generated in 0.38896 seconds with 50 queries
