Pitman arm question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2009, 09:38 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Pitman arm question
So i've been gathering parts to do crossover steering on my GM Dana 60, ORD uses part # 70203. Which is a Tuff Counrty part #, it's for a Ford 1976-1979 bronco/ f150. Are all the splines on the steering box's the same, or are they just the same for those years?? Also what makes it different from 1980 on??
Old December 27th, 2009, 09:41 PM   #2
boggin-machine
boggin-machine's Avatar
i know the 80s a different body style so id assume its a different frame specs as well. most likely a different pitch to it.
cross the numbers on a different site to verify
Old December 27th, 2009, 09:51 PM   #3
Hoss Blazer
!SPARTY ON!
Colorado K5 said they used a stock one off a Jeep Wrangler YJ
Old December 27th, 2009, 10:00 PM   #4
boggin-machine
now thats crazy. that seems a little off dont it?
Old December 27th, 2009, 10:03 PM   #5
Hoss Blazer
!SPARTY ON!
Ya i know, i'm gonna take my steering box in and see if the parts store have either in stock!
Old December 27th, 2009, 10:11 PM   #6
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Mine is for a Jeep that i used on my K5, But I'm sure that i told you that when you had ask me about my crossover steering before.
CHEVYRCKS is offline   Reply With Quote
Old December 28th, 2009, 06:04 AM   #7
Hoss Blazer
!SPARTY ON!
Ya i can't remember what year jeep you said though!!
What year is your box?? Mine is out of a 1981, will the jeep one fit mine?
Old December 28th, 2009, 09:26 AM   #8
Hoss Blazer
!SPARTY ON!
Here's the website I've found to do mine.
http://www.coloradok5.com/crossoversteering.shtml
Old December 28th, 2009, 10:18 AM   #9
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
yes it should fit, my gearbox was from a 79 and also had one from a 83
Old December 28th, 2009, 12:34 PM   #10
Hoss Blazer
!SPARTY ON!
What year jeep did you get it from? For the wrangler??
Old December 28th, 2009, 12:47 PM   #11
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
I used a wrangler pitman arm on my s10 box when I did mine
BAD93SBLZR is offline   Reply With Quote
Old December 28th, 2009, 12:54 PM   #12
Hoss Blazer
!SPARTY ON!
What year wrangler?
What year steering box did you use?
Also did you need to do anything special to the arm itself to make it fit?
Old December 28th, 2009, 01:25 PM   #13
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I would get one for a YJ 87-95 Should work with a two wheel drive gear box 73-87
Old December 28th, 2009, 01:29 PM   #14
Hoss Blazer
!SPARTY ON!
Thanks, did you have to drill the holes out at all to get a gm tie rod to fit?
Old December 28th, 2009, 09:02 PM   #15
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I used Heims joints so yes i had to drill them.
Old December 29th, 2009, 11:49 AM   #16
Hoss Blazer
!SPARTY ON!
Ah ok, won one on ebay last night and awaiting it's arrival!!!
Page generated in 0.33477 seconds with 71 queries
